Hi guys. 4 weeks ago i had to send my gtx 285 away for repair, the manufacturer told me the waiting list is extremely long. They offered me and i ended up getting to pay a small fee for a gtx 295 instead, which im happy about. Iv also noticed i wil have to get another powersupply as my current one will not run it.
My current specs are
intel i7 920 @ 3.3 (stock volts)
ud4p mobo
9800 1gb (courtesy card)
cpu cooler: noctua n-12p se
coolermaster sniper case
dvd burner
PC and Cooling silencer 750watts
the card there offering is
XFX NVIDIA GTX 295 PCI-E 2.0, 1792MB, DDR3, 896bit
"Minimum Power Supply Requirement: 730 Watt with one 6pin and one 8-pin"
So will my 750 watt run it? or will i have to upgrade?
So far iv looked around and this store down the main street of my town has these unknown power supplys that are really cheap
Ritmo Force 1200 Tri-Fan Gaming Power Supply
1200 Watt Tri-Fan Gaming Power Supply
# Complies switch with Intel 2.3 Version.
# 3 High quality fans for improved cooling and effeciency.
# Suitable for "ALWAYS ON" application.
# Speed thermal fan control function.
# Fan grill & black plated connectors, preventing rust and bad.
# Ultimate performance on efficiency & reliability.
# State of the art circuitry design & PCB layout.
# Home or office use.
# High energy power with lower ripple & noiseless.
# Short circuit & overload protecttion on all outputs.
Feature
Fan Size : 120mm + 80mm
I/O Switch : Yes
Temperatures Control: Yes
AC Cable : No
Connector : ATX 20+4Pin x1, Molex 4Pin x3, SATA x8, PCI-6+2Pin x2, FDD 4Pin, 12V CPU 4Pin x2, PCI-E 6Pin x4, 8Pin x1
Manufacturer Ritmo
Model Force 1200 Gaming
Watts 1200W
Voltage 2.3V
Amps 10A at 60Hz and 6A at 50Hz
Fan Size 120mm + 80mm x 2
I/O Switch Yes
Temperature Control Yes
AC Cable No
Connector ATX 20+4Pin x1
Molex 4Pin x3
SATA x8
PCI-6+2Pin x2
FDD 4Pin
12V CPU 4Pin x2
PCI-E 6Pin x4
8Pin x1
Package Dimensions (L x W x H) 30.5cm x 18cm x 11.5cm approx.
Product Dimensions (L x W x H) 15cm x 16.5cm x 8.7cm approx.
Package Weight 2.2kg
or should i spend alot more for something like the (more trustworthy)
Antec TruePower Quattro 1000W ATX Power Supply
Just wondering if anyone has heard of these
Ill probably lean to a know brand
ud4p mobo
dvd burner
Feature
I/O Switch : Yes
AC Cable : No
Manufacturer Ritmo
Watts 1200W
Voltage 2.3V
I/O Switch Yes
AC Cable No
Molex 4Pin x3
SATA x8
PCI-6+2Pin x2
FDD 4Pin
12V CPU 4Pin x2
PCI-E 6Pin x4
8Pin x1
