Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Intermittent noise from case?
Forum Homebuilt Systems : General Homebuilt - Intermittent noise from case?
I've had my tower for a little over a year now and tonight I noticed an intermittent noise coming from the case as it is running (a slight sort of screech, like rubber tires on the road maybe?). As I type this I don't hear it, and it seems not too bad, but I am concerned obviously for what it is. I have an intuitive guess that it may be an older hard drive failing/dying.
Does anyone have any ideas/any way for me to figure it out without moving it/adjusting the case? I'd rather not risk it here at school for the time being.
I also don't have transportation so I can't take it anywhere if need be.
Sponsored Links
Full system specs please, hard to guess what might be the source of the issue without knowing the candidates.
Reply to hunter315
Yes, full specs please. But another potential is a dying fan I suppose. Backup your data ASAP to be safe regardless.
------------------------------ New Build : Intel Core i5 750 > Gigabyte GA-P55-UD4P > 2x2GB GSkill 1600MHz CL7 1.65V > Samsung Spinpoint F3 1TB >
Antec 300 Illusion > Asus 4850 512MB w/AM Cooler > Corsair 650HX > CM Hyper 212 Plus > Other: PII 940/Gigabyte 790GX/4850 1G
Reply to EXT64
Open up the box and listen for the noise.
Reply to jsc
There are 708 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
