Help me decide on a PC case. Here's my build so far:
I7 975
ASUS Rampage Extreme II
Cooler Master V8
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
Windows XP Pro 64 till my Windows 7 upgrade arrives
And eventually
ATI 5870 Graphics card
2x Western Digital - VelociRaptor 300GB Internal SATA Hard Drive in raid 0
LG - 8x Internal Blu-ray Disc Double-Layer DVD±RW/CD-RW Drive
I'm thinking either an Antec case, the Cooler Master Haf 932 or Storm Scout.
did you just pick the most overpriced components or did do research?.975 total rip off a good clocked 920 will match it,the v8 is over rated,unless you into seriuos clocking you would never see half the rampage's features the asus pt6 v2 just as good, velociraptors is old tech newer 7200rpm drives will match it or get an ssd
The 975 was bought at a great price.
I don't over clock so why buy a 920?
The board came with an X-FI card. Separately a cheaper ASUS Board and X-FI card would've cost me more.
The v8 I can take back but it was what was recommended to me for both cooling and not being very loud. It cost me $70. It seemed to have a lower profile than some other CPU fans I've looked at.
I can't afford SSD's and how are 7200rpm hard drives faster than 10,000rpm hard drives? Velociraptor's are still rated better than any other drive except maybe cheetahs and of course SSD's.
Antec cases are not overrated... I would recommend the Antec 900 or Antec 1200. If you want Cooler Master, look at the CM RC-690, which is the best case price to performance, IMO, or pick up the HAF 922.
Don't pick up two VRaptors!!! It is not worth the price! You can pick up a great 60GB SSD for OS / few games and a second drive for storage (Samsung Spinpoint F3 500GB HDD for example) at same price or less. The Samsung Spinpoint F3 beats the VRaptor in many benchmarks due to the difference in platter size, which makes it so fast.
Back on cases. I need a case that will support an ASUS Rampage Extreme II, a Cooler Master v8 and an ATI HD-5870 but I'd like to keep the price to around $100 unless it has a PSU combo with at least an 850 WATT PSU. Does anyone know for sure that an Antec 900 or Cooler Master Storm Scout would work?
