Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > GTS 250 Power Question
Hey guys, I have recently bought a Palit GTS 250 gfx card and have a quick question.
The card has 2 6pin PCI-E power ports, but the cable that came with it only has 1 6pin connector that splits into 2 Molex connectors.
Is this powered right????
The card runs fine but I was just a tad curious
Thanks in advanced!!!!!!
Sponsored Links
If you are only using the single converted 6-pin connector, your card is not getting enough power. Furthermore, if your PSU does not have any 6-pin connectors, I highly recommend you buying a new PSU that supports the newer generation cards. For a GTS 250, you wouldn't need anything more than 550/600watts, but if you plan to SLI your cards, consider just a tad more power.
Reply to skolpo
Thats all that come with it though, they would have to supply you with the needed parts!
Reply to hestermofet
The card has 2 sockets which require you to have 2 6 pin PCIE power cables to plug into them.
Your Power supply should have these power cables on it to plug into the sockets.
They supply the adapter which is 2 Molex plugs converted to 1 PCIE plug because there are a lot of PSU's out there that have enough power to run a double socketed card but only have 1, 6 pin PCIE connector coming from the PSU. This is because having 2 sockets is a relatively new thing in the mainstream Graphics card market. So by providing the connector they are covering that possable need. They in no way have to supply this connector its just good business practice.
Now as skolpo said,
"If you are only using the single converted 6-pin connector, your card is not getting enough power. Furthermore, if your PSU does not have any 6-pin connectors, I highly recommend you buying a new PSU that supports the newer generation cards. For a GTS 250, you wouldn't need anything more than 550/600watts, but if you plan to SLI your cards, consider just a tad more power."
Mactronix :)
Message edited by mactronix on 10-07-2009 at 10:07:03 AM
Reply to mactronix
Both the molex connectors are attached aswell though
:) I thought i had been simplistic enough but i will try again.
1. if you buy a card that has 2 PCIE sockets then its up to you to make sure your Power supply has teh 2 6pin PCIE power cables needed to connect the card to the power it needs to run.
2. If you have got yourself a card that needs 2 power connectors and you find that you dont have enough power connectors even after using the cable provided, then sorry thats your fault for not checking in the first place.
Sounds to me like you have a PSU with 0 PCIE connectors and have used the addaptor to make 1 up ??
If thats correct then do you even have 2 more molex connectors left to make up another if you had another addaptor ??
Either way this still applies,
"If you are only using the single converted 6-pin connector, your card is not getting enough power. Furthermore, if your PSU does not have any 6-pin connectors, I highly recommend you buying a new PSU that supports the newer generation cards."
Mactronix
Reply to mactronix
There are 1178 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
