Yes No
Ads
Tom's Hardware > Forum > Storage > Hard Drives > [Solved] Crazy hard drive problem, challenge for experts. HELP!!
Forum Storage : Hard Drives [Solved] Crazy hard drive problem, challenge for experts. HELP!!
Best answer from fzabkar.
Hello,
Ok, it all began with simple error when my computer booted up.It would shut down while on the windows loading screen.Also when I went into safe mode it would say something about spdt.sys or something like that. after researching on the internet it seemed like everyone said to boot the recovery console and use fixboot and fixmbr. Unfortuneatly it now caused further problems and now my computer said "ntrld is missing". I tried to copy the file from my usb in the recovery console but it kept saying access denied.On the internet it said that it was due to not having the right admin password.The recovery password didnt even ask me for a passwordor to select my os!After that I booted up with linux to try and save my files but in linux it said that on the hard drive that there was only 10 mb of space total on the hard drive and I was using 3.1 mb of it( this is an 80 gb mind you). The folder was blank and unwriteable. After that I ran a chkdsk repair in recovery console and it gave the same details as the linux. I researched alittle more(by the way thanks for staying with me so far:))and found out that I should just try a simple repair from the windows xp cd. unfortueneatly I dont have one so I had to download an iso and burn it to a cd. I tried to use it but the seccond repair option never came up.I gave up on that decide to use my last resort which was to actually go into my computer and hook it up to my other computer as a slave. It did and said the same thing as linux. I put it back and did even more research and found no one had the same problem as me but some people reported their HD saying that there was only 32 mb on a hd with 1000 gb(1tb) so i assumed that it was the same problem just different proportions. They advised that you download ultimatebootcd and boot it. That fix didnt work either.although there was a disk diagnostic tool from the manufacturer(seagate)on the ultimatebootcd and it said that there was one error which it fixed but it didnt do anything to solve my problem. You are probably exhausted from reading all of this but Im asking for your help. This may even be a challenge for experts so Im not expecting much.
Thanks
Reply to hundredhead
I'm guessing that you have a Gigabyte motherboard with an Xpress Recovery BIOS. If so, then a bug in the BIOS has incorrectly truncated the drive after writing a backup of itself to a HPA.
See this thread for an explanation and solution:
http://forum.hddguru.com/lost-part [...] 15662.html
That said, the fact that you have used FIXMBR and FIXBOOT on your drive has made the abovementioned solution a lot harder. If I were recovering your data, I would do so manually by editing the partition table (which would have been damaged by FIXMBR), and the boot sector (which would have been damaged by FIXBOOT). However, I would first restore the full 1TB capacity of your drive using either HDAT2 or HDD Capacity Restore Tool.
One more thing ...
Could we see the partition table and boot sector with Microsoft's Sector Inspector?
http://www.users.on.net/~fzabkar/SecInspect.zip
Extract the above archive to the one folder (on another drive, not your patient drive) and execute the SIrun.bat file. The procedure will generate a report file named SIout.txt.
Reply to fzabkar
Sorry for making it seem like I left but my other computer wasnt boot properly. nothing to worry about though it's from 2003 and is really only ued in emergencys.
back to the task at hand, here is the SIout.txt. Im not sure what drive is which but the broken one is 80gb (not 1 tb you might've read wrong) the working drive is 40gb. And I also had a 4gb flash drive, and a broken cd rom in there if that matters.
This is before the hdd capacity restore because I couldnt get it to work. It kept saying that the drive are on the same channel. (Maybe I should use the cd master/slave cable?)
Heres the SIout.txt
Date and time:
Mon 07/25/2011
12:59 PM
0001.033
Sector Inspector Copyright Microsoft Corporation 2003
Target - \\.\PHYSICALDRIVE0
5169 Cylinders
240 Heads
63 Sectors Per Track
512 BytesPerSector
12 MediaType
Master Boot Record
| B | FS TYPE | START | END | | |
| F | (hex) | C H S| C H S| RELATIVE | TOTAL |
| | 0b | 0 1 0| 566 239 63| 63| 8572977|
| * | 07 | 567 0 1|1023 239 63| 8573040| 69567120|
| | 00 | 0 0 0| 0 0 0| 0| 0|
Disk Signature 0x1abd1abc
Partition #2 NTFS backup boot sector at LBN 78140159.
LBN 0 [C 0, H 0, S 1]
0x0000 33 f6 8b fe 8e d6 bc 00-7a b8 c0 07 bb a0 07 b9 3ö‹þŽÖ¼.z¸À.» .¹
0x0010 00 02 8e d8 8e c3 fc f3-a4 8e db ea 5d 00 a0 07 ..ŽØŽÃüó¤ŽÛê]. .
0x0020 10 00 01 00 00 7a 00 00-00 00 00 00 00 00 00 00 ....z..........
0x0030 bb 0e 00 ff 30 ff 31 8f-00 8f 01 80 eb 02 73 f3 »..ÿ0ÿ1..€ë.só
0x0040 c3 be be 01 b9 04 00 38-64 04 74 0d 38 44 04 74 þ¾.¹..8d.t.8D.t
0x0050 08 83 c6 10 e2 f1 e9 82-00 e8 d4 ff c3 bf ce 01 .ƒÆâñé‚.èÔÿÿÎ.
0x0060 b8 0b 12 e8 db ff bf be-01 b8 0c 07 e8 d2 ff c6 ¸.èÛÿ¿¾.¸..èÒÿÆ
0x0070 05 00 c6 45 10 00 c6 45-14 12 f6 06 42 01 04 75 ..ÆE.ÆEö.B..u
0x0080 39 f6 06 42 01 02 75 38-b4 01 cd 16 75 23 8a 16 9ö.B..u8´.Íu#Š
0x0090 41 01 0a d2 74 2a fe ca-78 26 36 8a 0e 6c 04 80 A..Òt*þÊx&6Š.l.€
0x00a0 c1 12 b4 01 cd 16 75 09-36 3a 0e 6c 04 75 f3 eb Á´.Íu.6:.l.uóë
0x00b0 e5 b4 00 cd 16 80 fc 44-75 06 c6 45 10 80 eb 0a å´.Í€üDu.ÆE€ë.
0x00c0 c6 05 80 f6 06 42 01 10-74 04 c6 45 14 0b f6 06 Æ.€ö.B.t.ÆE.ö.
0x00d0 42 01 40 74 06 be ce 01-e8 55 ff 80 26 42 01 f9 B.@t.¾Î.èUÿ€&B.ù
0x00e0 bf be 01 b9 04 00 80 3d-80 74 19 83 c7 10 e2 f6 ¿¾.¹..€=€tƒÇâö
0x00f0 8b 36 45 01 e8 36 00 8b-36 47 01 e8 2f 00 b4 00 ‹6E.è6.‹6G.è/.´.
0x0100 cd 16 cd 18 b8 00 43 b2-80 be 20 00 cd 13 72 e0 Í͸.C²€¾ .Írà
0x0110 66 8b 5d 08 66 89 1e 28-00 c6 06 25 00 7c b4 42 f‹].f‰(.Æ.%.|´B
0x0120 cd 13 8b 36 43 01 72 cc-ea 00 7c 00 00 60 bb 07 Í‹6C.rÌê.|..`».
0x0130 00 b9 01 00 ac 0a c0 74-06 b4 0e cd 10 eb f5 61 .¹..¬.Àt.´.Íëõa
0x0140 c3 01 51 4b 01 68 01 85-01 96 01 0d 0a 4d 69 73 Ã.QK.h.….–...Mis
0x0150 73 69 6e 67 20 6f 70 65-72 61 74 69 6e 67 20 73 sing operating s
0x0160 79 73 74 65 6d 0d 0a 00-0d 0a 4d 61 73 74 65 72 ystem.....Master
0x0170 20 42 6f 6f 74 20 52 65-63 6f 72 64 20 45 72 72 Boot Record Err
0x0180 6f 72 0d 0a 00 0d 0a 50-72 65 73 73 20 61 20 6b or.....Press a k
0x0190 65 79 2e 0d 0a 00 20 00-21 0d 0a 00 00 00 00 00 ey.... .!.......
0x01a0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01b0 00 00 00 00 00 00 41 01-bc 1a bd 1a 00 00 00 01 ......A.¼½....
0x01c0 00 00 0b ef bf 36 3f 00-00 00 31 d0 82 00 80 00 ...ï¿6?...1Ђ.€.
0x01d0 81 37 07 ef ff ff 70 d0-82 00 90 82 25 04 00 00 7.ïÿÿpЂ.‚%...
0x01e0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 55 aa ..............Uª
Primary Partition 1
FAT32 BIOS Parameter Block Information
BytesPerSector : 512
Sectors Per Cluster : 8
ReservedSectors : 32
Fats : 2
RootEntries : 0
Small Sectors : 0 ( 0 MB )
Media Type : 248 ( 0xf8 )
SectorsPerFat : 0
SectorsPerTrack : 63
Heads : 240
Hidden Sectors : 63
Large Sectors : 8572976 ( 4186 MB )
LargeSectorsPerFat : 8356
ExtendedFlags : 0
FsVersion : 0
RootDirFirstCluster : 2
FsInfoSector : 1
BackupBootSector : 6
Label :
LBN 63 [C 0, H 1, S 1]
0x0000 e9 a9 00 52 45 43 4f 56-45 52 59 00 02 08 20 00 é©.RECOVERY... .
0x0010 02 00 00 00 00 f8 00 00-3f 00 f0 00 3f 00 00 00 .....ø..?.ð.?...
0x0020 30 d0 82 00 a4 20 00 00-00 00 00 00 02 00 00 00 0Ђ.¤ ..........
0x0030 01 00 06 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0040 80 00 29 38 12 4d 50 20-20 20 20 20 20 20 20 20 €.)8MP
0x0050 20 20 46 41 54 33 32 20-20 20 66 c1 e0 02 8b d0 FAT32 fÁà.‹Ð
0x0060 81 e2 ff 01 66 c1 e8 09-66 3b 46 f8 74 2a 66 89 âÿ.fÁè.f;Føt*f‰
0x0070 46 f8 66 03 46 f4 66 0f-b6 5e 28 80 e3 0f 74 0f Føf.Fôf.¶^(€ã.t.
0x0080 3a 5e 10 0f 83 8d 00 66-0f af 5e 24 66 03 c3 bb :^.ƒ.f.¯^$f.û
0x0090 e0 07 b9 01 00 e8 d5 00-8b da 66 8b 87 00 7e 66 à.¹..èÕ.‹Úf‹‡.~f
0x00a0 25 ff ff ff 0f 66 3d f8-ff ff 0f c3 33 c9 8e d9 %ÿÿÿ.f=øÿÿ.Ã3ÉŽÙ
0x00b0 8e c1 8e d1 bc f4 7b bd-00 7c 66 0f b6 46 10 66 ŽÁŽÑ¼ô{½.|f.¶Ff
0x00c0 f7 66 24 66 0f b7 56 0e-66 03 56 1c 66 89 56 f4 ÷f$f.·V.f.Vf‰Vô
0x00d0 66 03 c2 66 89 46 fc 66-c7 46 f8 ff ff ff ff 66 f.Âf‰FüfÇFøÿÿÿÿf
0x00e0 8b 46 2c 66 50 e8 a5 00-bb 70 00 b9 01 00 e8 7c ‹F,fPè¥.»p.¹..è|
0x00f0 00 bf 00 07 b1 0b be 9e-7d f3 a6 74 2d 03 f9 83 .¿..±.¾ž}ó¦t-.ùƒ
0x0100 c7 15 81 ff 00 09 72 ec-66 40 4a 75 db 66 58 e8 ǁÿ..rìf@JuÛfXè
0x0110 48 ff 72 cf be a9 7d ac-84 c0 74 09 b4 0e bb 07 HÿrϾ©}¬„Àt.´.».
0x0120 00 cd 10 eb f2 98 cd 16-cd 18 66 58 ff 75 09 ff .Íëò˜ÍÍfXÿu.ÿ
0x0130 75 0f 66 58 66 83 f8 02-72 da 66 3d f8 ff ff 0f u.fXfƒø.rÚf=øÿÿ.
0x0140 73 d2 66 50 e8 46 00 3e-8b 9e 6b 01 32 ed 8a 4e sÒfPèF.>‹žk.2íŠN
0x0150 0d e8 19 00 c1 e1 05 3e-01 8e 6b 01 66 58 e8 f9 .è.Áá.>.Žk.fXèù
0x0160 fe 72 d1 8a 56 40 ea 00-00 00 20 00 20 60 66 6a þrÑŠV@ê... . `fj
0x0170 00 66 50 53 6a 00 51 6a-10 8b f4 b8 00 42 8a 56 .fPSj.Qj‹ô¸.BŠV
0x0180 40 cd 13 83 c4 10 be c1-7d 72 8c 61 c3 66 48 66 @̓ľÁ}rŒaÃfHf
0x0190 48 66 0f b6 56 0d 66 f7-e2 66 03 46 fc c3 4e 54 Hf.¶V.f÷âf.FüÃNT
0x01a0 4c 44 52 20 20 20 20 20-20 0d 0a 49 6e 76 61 6c LDR ..Inval
0x01b0 69 64 20 53 79 73 74 65-6d 20 44 69 73 6b 20 6f id System Disk o
0x01c0 72 0d 0a 44 69 73 6b 20-49 2f 4f 20 65 72 72 6f r..Disk I/O erro
0x01d0 72 0d 0a 50 72 65 73 73-20 61 20 6b 65 79 20 74 r..Press a key t
0x01e0 6f 20 72 65 73 74 61 72-74 0d 0a 00 00 00 00 00 o restart.......
Primary Partition 2
NTFS BIOS Parameter Block Information
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 240
Hidden Sectors : 8573040
Large Sectors : 0 ( 0 MB )
ClustersPerFRS : 246
Clust/IndxAllocBuf : 1
NumberSectors : 69567119 ( 33968.3 MB )
MftStartLcn : 786432
Mft2StartLcn : 4347944
SerialNumber : 5493345442693937738
Checksum : 0 (0x0)
LBN 8573040 [C 567, H 0, S 1]
0x0000 eb 52 90 4e 54 46 53 20-20 20 20 00 02 08 00 00 ëRNTFS .....
0x0010 00 00 00 00 00 f8 00 00-3f 00 f0 00 70 d0 82 00 .....ø..?.ð.pЂ.
0x0020 00 00 00 00 80 00 80 00-8f 82 25 04 00 00 00 00 ....€.€.‚%.....
0x0030 00 00 0c 00 00 00 00 00-28 58 42 00 00 00 00 00 ........(XB.....
0x0040 f6 00 00 00 01 00 00 00-4a 7a 48 3c 93 48 3c 4c ö.......JzH<“H<L
0x0050 00 00 00 00 fa 33 c0 8e-d0 bc 00 7c fb b8 c0 07 ....ú3ÀŽÐ¼.|û¸À.
0x0060 8e d8 e8 16 00 b8 00 0d-8e c0 33 db c6 06 0e 00 ŽØè.¸..ŽÀ3ÛÆ...
0x0070 10 e8 53 00 68 00 0d 68-6a 02 cb 8a 16 24 00 b4 èS.h..hj.ËŠ$.´
0x0080 08 cd 13 73 05 b9 ff ff-8a f1 66 0f b6 c6 40 66 .Ís.¹ÿÿŠñf.¶Æ@f
0x0090 0f b6 d1 80 e2 3f f7 e2-86 cd c0 ed 06 41 66 0f .¶Ñ€â?÷â†ÍÀí.Af.
0x00a0 b7 c9 66 f7 e1 66 a3 20-00 c3 b4 41 bb aa 55 8a ·Éf÷áf£ .ôA»ªUŠ
0x00b0 16 24 00 cd 13 72 0f 81-fb 55 aa 75 09 f6 c1 01 $.Ír.ûUªu.öÁ.
0x00c0 74 04 fe 06 14 00 c3 66-60 1e 06 66 a1 10 00 66 t.þ..Ãf`.f¡.f
0x00d0 03 06 1c 00 66 3b 06 20-00 0f 82 3a 00 1e 66 6a ...f;. ..‚:.fj
0x00e0 00 66 50 06 53 66 68 10-00 01 00 80 3e 14 00 00 .fP.Sfh...€>..
0x00f0 0f 85 0c 00 e8 b3 ff 80-3e 14 00 00 0f 84 61 00 .…..è³ÿ€>...„a.
0x0100 b4 42 8a 16 24 00 16 1f-8b f4 cd 13 66 58 5b 07 ´BŠ$.‹ôÍfX[.
0x0110 66 58 66 58 1f eb 2d 66-33 d2 66 0f b7 0e 18 00 fXfXë-f3Òf.·..
0x0120 66 f7 f1 fe c2 8a ca 66-8b d0 66 c1 ea 10 f7 36 f÷ñþŠÊf‹ÐfÁê÷6
0x0130 1a 00 86 d6 8a 16 24 00-8a e8 c0 e4 06 0a cc b8 .†ÖŠ$.ŠèÀä..̸
0x0140 01 02 cd 13 0f 82 19 00-8c c0 05 20 00 8e c0 66 ..Í.‚.ŒÀ. .ŽÀf
0x0150 ff 06 10 00 ff 0e 0e 00-0f 85 6f ff 07 1f 66 61 ÿ..ÿ....…oÿ.fa
0x0160 c3 a0 f8 01 e8 09 00 a0-fb 01 e8 03 00 fb eb fe àø.è.. û.è..ûëþ
0x0170 b4 01 8b f0 ac 3c 00 74-09 b4 0e bb 07 00 cd 10 ´.‹ð¬<.t.´.»..Í
0x0180 eb f2 c3 0d 0a 41 20 64-69 73 6b 20 72 65 61 64 ëòÃ..A disk read
0x0190 20 65 72 72 6f 72 20 6f-63 63 75 72 72 65 64 00 error occurred.
0x01a0 0d 0a 4e 54 4c 44 52 20-69 73 20 6d 69 73 73 69 ..NTLDR is missi
0x01b0 6e 67 00 0d 0a 4e 54 4c-44 52 20 69 73 20 63 6f ng...NTLDR is co
0x01c0 6d 70 72 65 73 73 65 64-00 0d 0a 50 72 65 73 73 mpressed...Press
0x01d0 20 43 74 72 6c 2b 41 6c-74 2b 44 65 6c 20 74 6f Ctrl+Alt+Del to
0x01e0 20 72 65 73 74 61 72 74-0d 0a 00 00 00 00 00 00 restart........
0x01f0 00 00 00 00 00 00 00 00-83 a0 b3 c9 00 00 55 aa ........ƒ ³É..Uª
Target - \\.\PHYSICALDRIVE1
10337 Cylinders
240 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
| * | 07 | 0 1 1|1023 239 63| 63| 156296322|
Disk Signature 0x13441343
Partition #1 NTFS backup boot sector at LBN 156296384.
0x0000 33 c0 8e d0 bc 00 7c fb-50 07 50 1f fc be 1b 7c 3ÀŽÐ¼.|ûP.Pü¾|
0x0010 bf 1b 06 50 57 b9 e5 01-f3 a4 cb bd be 07 b1 04 ¿.PW¹å.ó¤Ë½¾.±.
0x0020 38 6e 00 7c 09 75 13 83-c5 10 e2 f4 cd 18 8b f5 8n.|.uƒÅâôÍ‹õ
0x0030 83 c6 10 49 74 19 38 2c-74 f6 a0 b5 07 b4 07 8b ƒÆIt8,tö µ.´.‹
0x0040 f0 ac 3c 00 74 fc bb 07-00 b4 0e cd 10 eb f2 88 ð¬<.tü»..´.Íëòˆ
0x0050 4e 10 e8 46 00 73 2a fe-46 10 80 7e 04 0b 74 0b NèF.s*þF€~..t.
0x0060 80 7e 04 0c 74 05 a0 b6-07 75 d2 80 46 02 06 83 €~..t. ¶.uÒ€F..ƒ
0x0070 46 08 06 83 56 0a 00 e8-21 00 73 05 a0 b6 07 eb F..ƒV..è!.s. ¶.ë
0x0080 bc 81 3e fe 7d 55 aa 74-0b 80 7e 10 00 74 c8 a0 ¼>þ}Uªt.€~.tÈ
0x0090 b7 07 eb a9 8b fc 1e 57-8b f5 cb bf 05 00 8a 56 ·.ë©‹üW‹õË¿..ŠV
0x00a0 00 b4 08 cd 13 72 23 8a-c1 24 3f 98 8a de 8a fc .´.Ír#ŠÁ$?˜ŠÞŠü
0x00b0 43 f7 e3 8b d1 86 d6 b1-06 d2 ee 42 f7 e2 39 56 C÷ã‹Ñ†Ö±.ÒîB÷â9V
0x00c0 0a 77 23 72 05 39 46 08-73 1c b8 01 02 bb 00 7c .w#r.9F.s¸..».|
0x00d0 8b 4e 02 8b 56 00 cd 13-73 51 4f 74 4e 32 e4 8a ‹N.‹V.ÍsQOtN2äŠ
0x00e0 56 00 cd 13 eb e4 8a 56-00 60 bb aa 55 b4 41 cd V.ÍëäŠV.`»ªU´AÍ
0x00f0 13 72 36 81 fb 55 aa 75-30 f6 c1 01 74 2b 61 60 r6ûUªu0öÁ.t+a`
0x0100 6a 00 6a 00 ff 76 0a ff-76 08 6a 00 68 00 7c 6a j.j.ÿv.ÿv.j.h.|j
0x0110 01 6a 10 b4 42 8b f4 cd-13 61 61 73 0e 4f 74 0b .j´B‹ôÍaas.Ot.
0x0120 32 e4 8a 56 00 cd 13 eb-d6 61 f9 c3 49 6e 76 61 2äŠV.ÍëÖaùÃInva
0x0130 6c 69 64 20 70 61 72 74-69 74 69 6f 6e 20 74 61 lid partition ta
0x0140 62 6c 65 00 45 72 72 6f-72 20 6c 6f 61 64 69 6e ble.Error loadin
0x0150 67 20 6f 70 65 72 61 74-69 6e 67 20 73 79 73 74 g operating syst
0x0160 65 6d 00 4d 69 73 73 69-6e 67 20 6f 70 65 72 61 em.Missing opera
0x0170 74 69 6e 67 20 73 79 73-74 65 6d 00 00 00 00 00 ting system.....
0x0180 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0190 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01b0 00 00 00 00 00 2c 44 63-43 13 44 13 00 00 80 01 .....,DcCD..€.
0x01c0 01 00 07 ef ff ff 3f 00-00 00 82 e4 50 09 00 00 ...ïÿÿ?...‚äP...
0x01d0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
Primary Partition 1
ReservedSectors : 1
Fats : 2
RootEntries : 512
Small Sectors : 20739 ( 10 MB )
SectorsPerFat : 8
SectorsPerTrack : 17
Heads : 4
Hidden Sectors : 1
ClustersPerFRS : 142
Clust/IndxAllocBuf : 123
NumberSectors : 4705734185631875072 ( 2.29772e+015 MB )
MftStartLcn : 4703482183185089869
Mft2StartLcn : 14497966947786961236
SerialNumber : 8935350553963012096
Checksum : 2099531320 (0x7d244e38)
0x0000 eb 3c 90 4d 53 44 4f 53-35 2e 30 00 02 08 01 00 ë<MSDOS5.0.....
0x0010 02 00 02 03 51 f8 08 00-11 00 04 00 01 00 00 00 ....Qø.........
0x0020 00 00 00 00 80 00 29 00-00 00 00 4e 4f 20 4e 41 ....€.)....NO NA
0x0030 4d 45 20 20 20 20 46 41-54 31 32 20 20 20 33 c9 ME FAT12 3É
0x0040 8e d1 bc f0 7b 8e d9 b8-00 20 8e c0 fc bd 00 7c ŽÑ¼ð{ŽÙ¸. ŽÀü½.|
0x0050 38 4e 24 7d 24 8b c1 99-e8 3c 01 72 1c 83 eb 3a 8N$}$‹Á™è<.rƒë:
0x0060 66 a1 1c 7c 26 66 3b 07-26 8a 57 fc 75 06 80 ca f¡|&f;.&ŠWüu.€Ê
0x0070 02 88 56 02 80 c3 10 73-eb 33 c9 8a 46 10 98 f7 .ˆV.€Ãsë3ÉŠF˜÷
0x0080 66 16 03 46 1c 13 56 1e-03 46 0e 13 d1 8b 76 11 f.FV.F.ыv
0x0090 60 89 46 fc 89 56 fe b8-20 00 f7 e6 8b 5e 0b 03 `‰Fü‰Vþ¸ .÷æ‹^..
0x00a0 c3 48 f7 f3 01 46 fc 11-4e fe 61 bf 00 00 e8 e6 ÃH÷ó.FüNþa¿..èæ
0x00b0 00 72 39 26 38 2d 74 17-60 b1 0b be a1 7d f3 a6 .r9&8-t`±.¾¡}ó¦
0x00c0 61 74 32 4e 74 09 83 c7-20 3b fb 72 e6 eb dc a0 at2Nt.ƒÇ ;ûræëÜ
0x00d0 fb 7d b4 7d 8b f0 ac 98-40 74 0c 48 74 13 b4 0e û}´}‹ð¬˜@t.Ht´.
0x00e0 bb 07 00 cd 10 eb ef a0-fd 7d eb e6 a0 fc 7d eb »..Íëï ý}ëæ ü}ë
0x00f0 e1 cd 16 cd 19 26 8b 55-1a 52 b0 01 bb 00 00 e8 áÍÍ&‹UR°.»..è
0x0100 3b 00 72 e8 5b 8a 56 24-be 0b 7c 8b fc c7 46 f0 ;.rè[ŠV$¾.|‹üÇFð
0x0110 3d 7d c7 46 f4 29 7d 8c-d9 89 4e f2 89 4e f6 c6 =}ÇFô)}ŒÙ‰Nò‰NöÆ
0x0120 06 96 7d cb ea 03 00 00-20 0f b6 c8 66 8b 46 f8 .–}Ëê... .¶Èf‹Fø
0x0130 66 03 46 1c 66 8b d0 66-c1 ea 10 eb 5e 0f b6 c8 f.Ff‹ÐfÁêë^.¶È
0x0140 4a 4a 8a 46 0d 32 e4 f7-e2 03 46 fc 13 56 fe eb JJŠF.2ä÷â.FüVþë
0x0150 4a 52 50 06 53 6a 01 6a-10 91 8b 46 18 96 92 33 JRP.Sj.j‘‹F–’3
0x0160 d2 f7 f6 91 f7 f6 42 87-ca f7 76 1a 8a f2 8a e8 Ò÷ö‘÷öB‡Ê÷vŠòŠè
0x0170 c0 cc 02 0a cc b8 01 02-80 7e 02 0e 75 04 b4 42 ÀÌ..̸..€~..u.´B
0x0180 8b f4 8a 56 24 cd 13 61-61 72 0b 40 75 01 42 03 ‹ôŠV$Íaar.@u.B.
0x0190 5e 0b 49 75 06 f8 c3 41-bb 00 00 60 66 6a 00 eb ^.Iu.øÃA»..`fj.ë
0x01a0 b0 4e 54 4c 44 52 20 20-20 20 20 20 0d 0a 4e 54 °NTLDR ..NT
0x01b0 4c 44 52 20 69 73 20 6d-69 73 73 69 6e 67 ff 0d LDR is missingÿ.
0x01c0 0a 44 69 73 6b 20 65 72-72 6f 72 ff 0d 0a 50 72 .Disk errorÿ..Pr
0x01d0 65 73 73 20 61 6e 79 20-6b 65 79 20 74 6f 20 72 ess any key to r
0x01e0 65 73 74 61 72 74 0d 0a-00 00 00 00 00 00 00 00 estart..........
0x01f0 00 00 00 00 00 00 00 00-00 00 00 ac bf cc 55 aa ...........¬¿ÌUª
Target - \\.\PHYSICALDRIVE2
489 Cylinders
255 Heads
512 BytesPerSector
11 MediaType
Master Boot Record
| * | 0c | 0 1 1| 488 254 63| 63| 7864256|
Disk Signature 0x0019137e
0x0000 fa 31 c0 8e d8 8e d0 bc-00 7c 89 e6 06 57 8e c0 ú1ÀŽØŽÐ¼.|‰æ.WŽÀ
0x0010 fb fc bf 00 06 b9 00 01-f3 a5 ea 1f 06 00 00 52 ûü¿..¹..ó¥ê...R
0x0020 52 b4 41 bb aa 55 31 c9-30 f6 f9 cd 13 72 13 81 R´A»ªU1É0öùÍr
0x0030 fb 55 aa 75 0d d1 e9 73-09 66 c7 06 8d 06 b4 42 ûUªu.Ñés.fÇ..´B
0x0040 eb 15 5a b4 08 cd 13 83-e1 3f 51 0f b6 c6 40 f7 ëZ´.̓á?Q.¶Æ@÷
0x0050 e1 52 50 66 31 c0 66 99-e8 66 00 e8 21 01 4d 69 áRPf1Àf™èf.è!.Mi
0x0060 73 73 69 6e 67 20 6f 70-65 72 61 74 69 6e 67 20 ssing operating
0x0070 73 79 73 74 65 6d 2e 0d-0a 66 60 66 31 d2 bb 00 system...f`f1Ò».
0x0080 7c 66 52 66 50 06 53 6a-01 6a 10 89 e6 66 f7 36 |fRfP.Sj.j‰æf÷6
0x0090 f4 7b c0 e4 06 88 e1 88-c5 92 f6 36 f8 7b 88 c6 ô{Àä.ˆáˆÅ’ö6ø{ˆÆ
0x00a0 08 e1 41 b8 01 02 8a 16-fa 7b cd 13 8d 64 10 66 .áA¸..Šú{͍df
0x00b0 61 c3 e8 c4 ff be be 7d-bf be 07 b9 20 00 f3 a5 aÃèÄÿ¾¾}¿¾.¹ .ó¥
0x00c0 c3 66 60 89 e5 bb be 07-b9 04 00 31 c0 53 51 f6 Ãf`‰å»¾.¹..1ÀSQö
0x00d0 07 80 74 03 40 89 de 83-c3 10 e2 f3 48 74 5b 79 .€t.@‰ÞƒÃâóHt[y
0x00e0 39 59 5b 8a 47 04 3c 0f-74 06 24 7f 3c 05 75 22 9Y[ŠG.<.t.$<.u"
0x00f0 66 8b 47 08 66 8b 56 14-66 01 d0 66 21 d2 75 03 f‹G.f‹Vf.Ðf!Òu.
0x0100 66 89 c2 e8 ac ff 72 03-e8 b6 ff 66 8b 46 1c e8 f‰Âè¬ÿr.è¶ÿf‹Fè
0x0110 a0 ff 83 c3 10 e2 cc 66-61 c3 e8 62 00 4d 75 6c  ÿƒÃâÌfaÃèb.Mul
0x0120 74 69 70 6c 65 20 61 63-74 69 76 65 20 70 61 72 tiple active par
0x0130 74 69 74 69 6f 6e 73 2e-0d 0a 66 8b 44 08 66 03 titions...f‹D.f.
0x0140 46 1c 66 89 44 08 e8 30-ff 72 13 81 3e fe 7d 55 Ff‰D.è0ÿr>þ}U
0x0150 aa 0f 85 06 ff bc fa 7b-5a 5f 07 fa ff e4 e8 1e ª.….ÿ¼ú{Z_.úÿäè
0x0160 00 4f 70 65 72 61 74 69-6e 67 20 73 79 73 74 65 .Operating syste
0x0170 6d 20 6c 6f 61 64 20 65-72 72 6f 72 2e 0d 0a 5e m load error...^
0x0180 ac b4 0e 8a 3e 62 04 b3-07 cd 10 3c 0a 75 f1 cd ¬´.Š>b.³.Í<.uñÍ
0x0190 18 f4 eb fd 00 00 00 00-00 00 00 00 00 00 00 00 ôëý............
0x01b0 00 00 00 00 00 00 00 00-7e 13 19 00 00 00 80 01 ........~...€.
0x01c0 01 00 0c fe 7f e8 3f 00-00 00 c0 ff 77 00 00 00 ...þè?...Àÿw...
Primary Partition 1
Sectors Per Cluster : 4
Fats : 2
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 63
Large Sectors : 7864256 ( 3839 MB )
LargeSectorsPerFat : 15301
ExtendedFlags : 0
FsVersion : 0
FsInfoSector : 1
Label :
0x0000 eb 58 90 4d 53 57 49 4e-34 2e 31 00 02 04 20 00 ëXMSWIN4.1... .
0x0010 02 00 00 00 00 f8 00 00-3f 00 ff 00 3f 00 00 00 .....ø..?.ÿ.?...
0x0020 c0 ff 77 00 c5 3b 00 00-00 00 00 00 02 00 00 00 Àÿw.Å;..........
0x0040 80 01 29 1d 21 fc 10 4e-4f 20 4e 41 4d 45 20 20 €.)!üNO NAME
0x0050 20 20 46 41 54 33 32 20-20 20 fa fc 31 c0 8e d0 FAT32 úü1ÀŽÐ
0x0060 bc b4 7b 06 57 8e c0 b9-08 00 bf b4 7b f3 a5 8e ¼´{.WŽÀ¹..¿´{ó¥Ž
0x0070 d8 bb 78 00 0f b4 37 0f-a0 56 88 16 25 28 20 d2 Ø»x..´7. Vˆ%( Ò
0x0080 78 15 b1 06 89 3f 89 47-02 f3 64 a5 8a 0e 18 7c x±.‰?‰G.ód¥Š.|
0x0090 88 4d f8 cd 13 eb 27 f6-45 f0 7f 75 08 66 8b 45 ˆMøÍë'öEðu.f‹E
0x00a0 f8 66 a3 1c 7c b4 08 cd-13 72 13 20 e4 75 0f c1 øf£|´.Ír äu.Á
0x00b0 ea 08 42 89 16 1a 7c 83-e1 3f 89 0e 18 7c fb bb ê.B‰|ƒá?‰.|û»
0x00c0 aa 55 b4 41 8a 16 25 28-cd 13 72 10 81 fb 55 aa ªU´AŠ%(ÍrûUª
0x00d0 75 0a f6 c1 01 74 05 c6-06 02 7d 00 66 a1 f8 7d u.öÁ.t.Æ..}.f¡ø}
0x00e0 bb 00 7e e8 10 00 66 81-3e 24 7e c9 dd 06 75 0f ».~è.f>$~ÉÝ.u.
0x00f0 85 c3 00 e9 3a 02 bd 01-00 66 03 06 1c 7c 66 31 …Ã.é:.½..f..|f1
0x0100 d2 eb 4f 55 e8 d5 00 66-0f b7 fd b9 10 00 66 52 ÒëOUèÕ.f.·ý¹.fR
0x0110 66 50 06 53 57 6a 10 89-e6 66 60 8a 16 25 28 1e fP.SWj‰æf`Š%(
0x0120 16 1f b4 42 cd 13 1f 66-61 8d 64 10 72 10 5d 66 ´BÍfadr]f
0x0130 01 f8 29 fd c1 e7 09 01-fb 21 ed 75 c6 c3 66 60 .ø)ýÁç..û!íuÆÃf`
0x0140 31 c0 8a 16 25 28 cd 13-66 61 e2 c2 c6 06 02 7d 1ÀŠ%(ÍfaâÂÆ..}
0x0150 4f 5d 66 52 66 50 55 53-66 0f b7 36 18 7c 66 0f O]fRfPUSf.·6|f.
0x0160 b7 3e 1a 7c 66 f7 f6 31-c9 87 ca 66 f7 f7 e8 6b ·>|f÷ö1ɇÊf÷÷èk
0x0170 00 29 ce 39 f5 76 02 89-f5 c0 e4 06 41 08 e1 88 .)Î9õv.‰õÀä.A.áˆ
0x0180 c5 88 d6 8a 16 25 28 95-b4 02 bd 10 00 66 60 cd ň֊%(•´.½.f`Í
0x0190 13 66 61 72 17 66 0f b6-c8 c1 e0 09 5b 01 c3 5d farf.¶ÈÁà.[.Ã]
0x01a0 66 58 66 5a 66 01 c8 29-cd 75 a7 c3 4d 75 de 95 fXfZf.È)Íu§ÃMuÞ•
0x01b0 d1 2e fc 7d 75 df 31 f6-8e d6 bc b0 7b 8e de 66 Ñ.ü}uß1öŽÖ¼°{ŽÞf
0x01c0 8f 06 78 00 be e7 7d ac-20 c0 74 09 b4 0e bb 07 .x.¾ç}¬ Àt.´.».
0x01d0 00 cd 10 eb f2 98 cd 16-cd 19 eb fe 3b 2e fc 7d .Íëò˜ÍÍëþ;.ü}
0x01e0 76 04 8b 2e fc 7d c3 42-6f 6f 74 20 65 72 72 6f v.‹.ü}ÃBoot erro
0x01f0 72 0d 0a 00 00 00 00 00-ae 77 00 00 7f 00 55 aa r.......®w...Uª
Date and time:
Mon 07/25/2011
12:59 PM
0001.033
5169 Cylinders
240 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
Primary Partition 1
Fats : 2
RootEntries : 0
SectorsPerFat : 0
Heads : 240
Hidden Sectors : 63
ExtendedFlags : 0
FsVersion : 0
FsInfoSector : 1
Label :
Primary Partition 2
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 240
Checksum : 0 (0x0)
10337 Cylinders
240 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
Primary Partition 1
ReservedSectors : 1
Fats : 2
RootEntries : 512
SectorsPerFat : 8
Heads : 4
Hidden Sectors : 1
489 Cylinders
255 Heads
512 BytesPerSector
11 MediaType
Master Boot Record
Primary Partition 1
Fats : 2
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 63
ExtendedFlags : 0
FsVersion : 0
FsInfoSector : 1
Label :
Iused my cd master/slave cable on the broken hard drive in order to use capacity restore it said that my harddrive was at full capacity and had nothing to restore but I then went into my coputer looked at the hard drive and it said 2.98 mb free, 10.1 mb total. Anymore fixes
Best answer
Sorry, I misread your first post. I mistook your drive as being a 1TB rather than an 80GB.
In fact it is at full capacity. Sector Inspector is reporting the size of PHYSICALDRIVE1 as ...
10337 Cylinders x 240 Heads x 63 Sectors Per Track x 512 BytesPerSector
= 80,023,265,280 bytes
The problem is that Microsoft's FIXBOOT has trashed your original NTFS boot sector (LBN 63) by replacing it with a 10MB FAT12 boot sector. FAT12 is the file system that was used on floppy diskettes and on sub-32MB HDDs. It beggars belief why any programmer would do such a stupid thing.
Anyway, the good news is that the partition table (LBN 0) is still intact, and Sector Inspector appears to have found an NTFS backup boot sector at LBN 156296384. This means that your data recovery software will be able to replace the damaged boot sector with the backup copy.
However, to make sure that your data recovery software won't be confused by the bogus boot sector, I suggest you use a disc editor to zero its contents. I use HxD, but another good freeware tool is DMDE.
http://mh-nexus.de/en/hxd/
http://softdm.com/download.html
If you choose HxD, then go to Extras -> Open disk, select your Physical disk, and uncheck the Open as Readonly box. You should see sector 0. Type "63" into the Sector box and hit Enter. You should now see the FAT12 boot sector. Compare it against Sector Inspector's report to be absolutely sure you are at the right point on the right drive. Now type 0 (zero) until sector 63 is erased. You should have now zeroed offsets 7E00 through 7FFF (ie just before 8000).
Confirm that sector 156296384 is an NTFS boot sector. It should have an NTFS signature near the beginning, and it should be similar in structure to LBN 8573040 in your Sector Inspector report. Don't do anything to it, though.
Now save and exit. At this point it would be safest to use a tool such as TestDisk (freeware) to reconstruct your boot sector from the backup.
http://www.cgsecurity.org/wiki/TestDisk
After running TestDisk, you may need to reboot in order for your OS to redetect your repaired drive.
Note that you will be back to your original problem, which appears to be some kind of file system corruption. TestDisk may be able to help you with this. However, I would first run CHKDSK against the drive, in readonly mode. Don't allow it to repair anything.
I would also use the HDD manufacturer's diagnostic tool to perform a surface scan of the drive in order to locate any bad sectors, before attempting to repair the file system.
Reply to fzabkar
it think i messed up. In test disk I went into analyze disk chose intel/pc and it analyzed. Then It asked me if I wanted to load partition sturctiure from back up. I chose yes and it loaded. I turned off the computer and turned it back on went into the folder in my computer it said that the disk needed to be formatted. Is all the data gone now?
Message edited by hundredhead on 07-27-2011 at 12:56:23 AM
I'd say your data are still there. That said, I can't understand why TestDisk asked you if you wanted to load the partition "structure".
Could you show us the updated Sector Inspector report for PHYSICALDRIVE1?
Reply to fzabkar
Date and time:
Wed 01/02/2002
01:49 AM
0001.033
5169 Cylinders
240 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
Primary Partition 1
Fats : 2
RootEntries : 0
SectorsPerFat : 0
Heads : 240
Hidden Sectors : 63
ExtendedFlags : 0
FsVersion : 0
FsInfoSector : 1
Label :
Primary Partition 2
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 240
Checksum : 0 (0x0)
10337 Cylinders
240 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
Primary Partition 1
BytesPerSector : 0
Sectors Per Cluster : 0
ReservedSectors : 0
Fats : 0
RootEntries : 0
Media Type : 0 ( 0x0 )
SectorsPerFat : 0
SectorsPerTrack : 0
Heads : 0
Hidden Sectors : 0
ClustersPerFRS : 0
Clust/IndxAllocBuf : 0
NumberSectors : 0 ( 0 MB )
MftStartLcn : 0
Mft2StartLcn : 0
SerialNumber : 0
Checksum : 0 (0x0)
0x0000 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0010 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0020 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0030 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0040 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0050 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0060 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0070 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0080 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0090 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00a0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00b0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00c0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00d0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00e0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0100 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0110 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0120 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0130 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0140 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0150 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0160 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0170 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01b0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01c0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
489 Cylinders
255 Heads
512 BytesPerSector
11 MediaType
Master Boot Record
Primary Partition 1
Fats : 2
RootEntries : 0
SectorsPerFat : 0
Heads : 255
Hidden Sectors : 63
ExtendedFlags : 0
FsVersion : 0
FsInfoSector : 1
Label :
I don't understand what TestDisk has done. In fact it doesn't appear to have done anything.
You appear to have correctly zeroed the boot sector (63). Was the backup boot sector intact? If so, then TestDisk should have used it to repair LBN 0.
Can you see your file system with Partition Find and Mount?
http://findandmount.com/
Partition Find and Mount mounts your partition in read-only mode. It won't write any changes to your drive. If you can see your data, then copy it to a safe place.
To repair your boot sector, you could use a point-and-click solution such as Recuva. Alternatively you could manually copy the contents of the backup boot sector to sector 63. You could use HxD to do this, but you will make a bigger mess if you do it incorrectly.
Reply to fzabkar
My computer says that the Hard drive is RAW. 0bytes used 0bytes free.
btw partition mount and find didnt work
In test disk it says the backup boot sector is bad as well as the normal boot sector
Message edited by hundredhead on 07-27-2011 at 09:26:09 PM
Don't be concerned by the "RAW" message. This is to be expected when the boot sector is invalid. It just means that the OS cannot recognise the file system, in which case it treats the partition as just a bunch of bytes.
That said, I can't understand why data recovery software is having such a difficult time reconstructing sector 63. This seems like an extremely simple task to me. In fact I have had a very similar problem where a FAT32 file system was trashed by FIXBOOT. In my case I rebuilt the boot sector manually (because the backup wasn't an exact copy).
Could you show us the contents of the backup boot sector, ie sector 156296384?
Reply to fzabkar
unfortunately, everything from sector 156296384 down is blank(as in zeros).
i Used testdisk to rebuild the bootsector and everything was fixed. I can see that all my files are safe. in the my computer hard drive.
Is there anything else that should be done before I put the harddrive back into it's proper computer?
Thanks for all your help!
Message edited by hundredhead on 07-28-2011 at 09:20:29 PM
um I put the hard drive back in but it it wont boot. It just hangs on a black screen with a flashing dash at the top.
I don't understand why the backup boot sector was empty. That said, I'm happy that you recovered your data.
As for why your drive doesn't boot, perhaps there is some difference between the file system data in sector 0 and sector 63?
Could you show us what the boot sector (63) looks like now?
Your MBR looks similar to the standard Windows XP/2K MBR code:
http://thestarman.pcministry.com/asm/mbr/Win2kmbr.htm
Your boot sector should look similar to this one:
http://thestarman.pcministry.com/a [...] rHexEd.htm
Reply to fzabkar
10337 Cylinders
240 Heads
512 BytesPerSector
12 MediaType
Master Boot Record
Primary Partition 1
ReservedSectors : 0
Fats : 0
RootEntries : 0
SectorsPerFat : 0
Heads : 240
Hidden Sectors : 63
NumberSectors : 156296321 ( 76316.6 MB )
MftStartLcn : 613
Mft2StartLcn : 8126
SerialNumber : 0
Checksum : 0 (0x0)
0x0000 00 00 00 4e 54 46 53 20-20 20 20 00 02 08 00 00 ...NTFS .....
0x0010 00 00 00 00 00 f8 00 00-3f 00 f0 00 3f 00 00 00 .....ø..?.ð.?...
0x0020 00 00 00 00 00 00 00 00-81 e4 50 09 00 00 00 00 ........äP.....
0x0030 65 02 00 00 00 00 00 00-be 1f 00 00 00 00 00 00 e.......¾......
0x0040 f6 00 00 00 01 00 00 00-00 00 00 00 00 00 00 00 ö...............
The boot sector (63) contains a BIOS Parameter Block (BPB) at the beginning. The BPB defines the structure of the volume, ie BytesPerSector, Sectors Per Cluster, SectorsPerTrack, NumberSectors, etc.
After the BPB there should be boot code (similar to sector 8573040 of PHYSICALDRIVE0). The absence of the is code is what renders your drive unbootable. Normally you would fix this problem using FIXBOOT, but this brain-dead utility is what caused the problem in the first place. :-(
If you are feeling courageous, you could try FIXBOOT again. If sector 63 is trashed once more, you will at least be able to restore it to its current state by hand. Should this happen, I have another idea to get the drive bootable, but it will involve copying one sector over another.
Message edited by fzabkar on 08-01-2011 at 02:34:48 AM
Reply to fzabkar
fixboot worked but it would still stop in the middle of the loading screen so i went into the cd and used the repair option. It repairent apparently tried to reinstall windows after i booted it up. I was afarid it would reformat my harddrive so I turned it off and put it back into the other computer as slave. The files are still there but im afarid to put it back into the normal computer.
It appears that you are back to where you started, ie with a corrupt file system.
At this point you could run CHKDSK in readonly mode. This should tell you where the problems are.
Reply to fzabkar
chkdsk didnt help. when i start the computer it tries to restart windows setup from when i used repair but all it does is endup on a black screen with a cursor.
Message edited by hundredhead on 08-01-2011 at 08:27:21 PM
CHKDSK won't repair anything in readonly mode.
You need to type ...
CHKDSK /f
See ...
http://support.microsoft.com/kb/315265
http://www.microsoft.com/resources [...] hkdsk.mspx
However, I suggest you backup your important files before allowing CHKDSK to repair your file system.
Reply to fzabkar
chkdsk did repair 1 error but didnt change anything. The computer still says "setup is restarting" and then goes to a black screen with a single cursor when i start it up.
Message edited by hundredhead on 08-02-2011 at 02:02:26 AM
I was hoping that someone would offer an alternative suggestion, but ISTM that your most expedient solution is to backup your data and then reformat and rebuild your drive. Zero-filling your drive should retest and remap any bad sectors.
Reply to fzabkar
I found out that it was a registry problem. Since my problem no longer fits the sub-fourm "Hard Drives" I think It should be closed now(if you do that on here). I posted a question relating to the registry in the windows xp general disscussion section.
Thank you so much fzabkar for all your help!
This thread is continued here http://www.tomshardware.com/forum/ [...] ms#t939431
Message edited by hundredhead on 08-04-2011 at 02:53:13 AM
There are 1929 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
HDD Setup Help
By price_th, 13 hours ago:
Yes, Window will create a partition on a drive with none.
Best offers
Top experts
