O overclock98 Distinguished Dec 17, 2011 61 0 18,640 Dec 19, 2011 #1 Well I just overclocked my i7 2600k 4.7ghz and now i want to overclock my ram i tried overclocking it before but i couldnt boot in after that i use kvr1333d3n9/4g-sp ram i want to clock it at 1600 mhz
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Dec 19, 2011 #2 Hi and welcome to Tom's forum. What settings are you using? Is the CPU stable without overclock the RAM? Upvote 0 Downvote
O overclock98 Distinguished Dec 17, 2011 61 0 18,640 Dec 19, 2011 #3 thanks for the warm welcome I am using these settings yes it is stable Upvote 0 Downvote
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Dec 19, 2011 #4 Ok, so, what options are you changing for overclock the RAM? Upvote 0 Downvote
O overclock98 Distinguished Dec 17, 2011 61 0 18,640 Dec 19, 2011 #5 i am changing memory multiplier(1600) and memory voltage(1.65v) Upvote 0 Downvote
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Dec 19, 2011 #6 Try using the same multiplier but changing the CL from 9 to 8. Upvote 0 Downvote
O overclock98 Distinguished Dec 17, 2011 61 0 18,640 Dec 19, 2011 #7 what if it doesnt boot i cant change that in bios can i? dp67gb mobo and same voltage for default 1.5v Upvote 0 Downvote
saint19 Polypheme Mar 20, 2009 15,746 26 60,540 Dec 19, 2011 #8 Ok, you are using an Intel mobo and that's far away from be a good one for overclock. You can try and see if the BIOS gives you that option. Upvote 0 Downvote
O overclock98 Distinguished Dec 17, 2011 61 0 18,640 Dec 19, 2011 #9 didnt work out i found cl and rest in bios tho btw how long can my cpu run on 4.7 ghz? Upvote 0 Downvote
