L laakfam Honorable Mar 1, 2012 2 0 10,510 Mar 2, 2012 #1 I have a laptop with windows 7 64 bit system, can I wipe out the windows 7 64 bit and reload the computer with windows XP Pro 32 bit program or must I use Windows XP Pro 64 bit ?
PhilFrisbie Splendid Apr 22, 2006 6,472 3 26,465 Mar 2, 2012 #2 Yes, but it will only use about 3.5GB of the RAM. But beware that you might have a difficult time finding XP drivers for a newer laptop. Also, forget about XP 64-bit: the driver situation is VERY poor. Upvote 0 Downvote
L laakfam Honorable Mar 1, 2012 2 0 10,510 Mar 2, 2012 #3 Thank You Phil, I appreciate your help Upvote 0 Downvote
