I would like some recommendations and opinions on the brands i chose and their reliability and performance
Any graphics card suggestions (single card, not CrossfireX yet) that would be able to be CrossfireX compatible at a later date preferably under $125
(Stupid question, but would like to confirm that 790FX-GD70 is NOT SLI compatible)
Lastly, The MSI 790FX-GD70 states "Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max"
Does this mean that it will only support 1333 as it's highest speed for compatibility and it must be OC'd to 1600/1800 etc? Or is it compatible with Factory 1600mhz etc.
That is all for my extraordinarily long post, thanks for your opinions
The 790FX chipset does not support SLI, but it does support 16/16 crossfire, pick up an XFX 4850 1GB card for about 125, it should play everything on high easily and you can add another one in down the road.
What is means is that it will only automatically set the speed up to 1333MHz, anything above that you have to set manually and you should anyway. If you have ram rated at 1600 all you have to do is set it to 1600 and it will run fine.
Stop worrying about DRAM frequency. It has almost no effect on performance. More important is latency.
The memory controller is on the CPU. Currently, AMD CPUs do not support anything higher than 1333... although yes it's fairly easy to overclock, again the benefit is nothing.
That's not to say you should only buy 1333Mhz memory. Nothing wrong with margin. Maybe some future CPU will actually make use of it.
When you mean not quiet as in very loud? As in highly audible outside the case even? It recieved great ratings everywhere i looked and has a decent price. Not taking price into account, is the Antec EA750 or the Corsair 750TX better?
On the 4850 side, is the HIS HD 4850 IceQ4 Turbo a better choice due to cooling and quietness, since i most likely do not need the 1gb of memory due to lower resolution(i think?)
Only $110 after rebate
Well, the 750TX is about as loud as a normal 120mm case fan on full. It's not hair dryer loud or anything I can easily hear it over three quiet Scythe case fans running at half speed, when my GPU fan isn't drowning everything else out.
I believe the EA750 is a bit quieter. It has excellent reviews also.
From what I have learned about fan design recently, I strongly suspect that this is the card you want:
http://www.newegg.com/Product/Prod [...] 6814161297 The open sides are supposed to reduce noise, and your case has the airflow to deal with this type of cooling.
