Yes the fans will run at 100% all time, you can connect your fans to the motherboard it has 3 pin connectors and control then from BIOS . If you have to many fans buy a fancontroller , is the best solution.
I'm onboard with the fan controller idea- this would at least give you control to speed the fans up and down as you want. Otherwise, just go straight to the molex...skip the built-in 'controller' on the H100- it's mediocre at best.
