Flash drive: PNY 4gb mini attache, about a year old
What I did to it: used windows disk manager to write an IMG file (chrome OS) to flash drive, successfully booted.
I used windows 7 built in format tool to reformat my flash drive; it said default size is 1.00gb but I clicked format anyway.
The format worked but I had a 1gb flash drive (instead of 4gb) so I pulled out the flash drive and plugged it back in but windows explorer didnt detect it.
The situation: I used HP Disk Format Tool, it detected the drive and correctly had the drive size (4gb) but when I try to reformat it I get the error: The drive is write protected.
I went through Disk Management and the drive is shown but without a drive letter. I select Change Drive letters and Paths but I get the error: The system cannot find the file specified. Same error when trying to format through this method.
Please help!
Please help!
