Ok , so I didn't do any research on the GeForce 9500GS before buying my OEM computer from HP. Needless to say, big mistake. I have already replaced it through HP's replacement program once, and about a month later, I'm having problems with it again.
I am looking to replace it with another card. I would like better performance but realize that for the really good cards I'd have to upgrade my power supply as well.
So my question is what card can I replace it with, that uses the same amount of power?
18 amps ain't that bad! I just tossed a PSU at work that had 4 amps on the 12 volt rail. I kid you not! It was one of those PSUs that had more amperage on the 3 and 5 volt rails.
According to ATI, you'd need a 400 watt PSU for that 4670...
I think I'll go with the 4670 and hope it works. If it doesn't I'll likely be back to ask about upgrading the PSU which in turn means I'll need information on getting a new case. Which makes things complicated and probably pretty pricey.
I went for this one because I figured memory clock speed would be more useful to me than extra video memory. I am extremely happy with it. My computer is nice and quiet now, and my Windows experience index on Win7 has gone from 5.2 for graphics with my old card to 6.8.
