Hi guys!
I have been reading up on water cooling a lot lately, trying to get a feel for it and understand all the intricacies, and I think I have found a solution that I will like. I have an idea of what it would look like in my system and I think I have a solid list of components, but I want your guys' opinions and suggestions.
Everything I have put together so far is from www.frozencpu.com and it really is getting expensive, so my first question is where can I find similar quality or better components for cheaper? MountainMods.com didn't seem to have everything and I'm not sure of an all-in-one system (besides the Corsair H100, which looks decent).
I actually have a Corsair H50 already and it works great, but I want to build a full water system myself! That said, here is where I stand:
Theme will be a black case (Obsidian 800D) with an AX850 (single-sleeve braided black) with black fittings, white tubing, and black/white fans(I like the black and white). I am planning on a loop like this - please correct me if this loop could be better:
RADIATOR > CPU > NB/SB > MOSFET > RES > PUMP > RADIATOR
Here is an example from Digital-Storm:
While it will look similar, it won't include a loop for the GPUs or the single 120.1 radiator on the back or a bay-mounted reservoir. This is the color scheme I plan on going with.
Here is the component list:
EK X58 NB/SB/MOSFET Block @ $115.95
EK Supreme HF CPU Block @ $71.95
PrimoChill 3/8 ID 1/2 OD White Tubing x 10 Feet @ $22.95
Koolance 3/8" x 1/2" (10mm x 13mm) G 1/4 Threaded Compression Nozzle x 12 @ $71.88
Black Ice GTX360 Xtreme Radiator @ $119.95
Koolance 45 Degree Rotary Adapter x 6 @ $62.94
Danger Den DD-CPX Pro 12V 3 Pin Powered Pump - 237 GPH @ $56.95
EK-MultiOption RES X2 - 250 Advanced @ $55.95
NZXT 120mmx25mm High Performance Fan x 3 @ $26.97
NZXT 140mmx25mm High Performance Fan x 2 @ $21.98
Scythe Kaze Master Pro 5.25" 6 Channel Fan Controller @ $48.99
Corsair Obsidian 800D @ $250-$300
Corsair AX850 80+ Gold @ $150-200
Total: Over $1100 - I want to lower this as much as possible while keeping the highest quality.
That cost doesn't even include buying the cable sleeving and heatshrink necessary to achieve an MDPC look:
These systems are undoubtedly expensive but they look so good - This is the best example of the sleeving I want to do!
I think I'm getting ambitious but I feel confident that I can do it myself and make it look just as good. I would definitely prefer to pay less than $1100 while being able to achieve everything I want.
So there is the full list. For convenience, everything is linked to FrozenCpu.com - I know I can get some components cheaper elsewhere (Newegg and Amazon) and I certainly will - I just want thoughts / opinions / suggestions on what is listed, and perhaps a less expensive place for some of the items such as the base components for the water loop(blocks, etc).
I currently have a Seventeam ST-850Z 80+ Bronze but it spent a year in storage due to a deployment and I don't know how much longer it will last, and their customer service has proven impossible to contact. I also have a CoolerMaster Cosmos S chassis, and while it works just fine, it's not part of my "dream machine" build and therefore I will sell it. Too bad really, it is a spacious case, just not what I have mind! Besides, I am a Corsair fanboy anyway
Lastly, I want to mount the radiator and fans as shown in the Digital Storm PC, but I'm not sure how long and what type of threaded screws are required - input on this is greatly appreciated. I'd cry if I punctured the radiator.
Full PC components:
EVGA X58 E758-A1
Core i7-290 @ 3.2Ghz
6GB Corsair XMS3 @ 1600Mhz
2x MSI GTX560 Ti Hawk
Asus Xonar D2
1TB Western Digital Caviar Green (took it out of its previous external closure..It's now my main drive due to a failure of previous drives being very old - 5 years - and the fact that HDD prices are incredible right now)
Long post for sure, but I wanted to convey my thoughts and I hope I have shown that I did some research into components and how a system is supposed to work, but maybe not on their prices! Thanks for your time, everyone.
Full PC components:
EVGA X58 E758-A1
Asus Xonar D2
