Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] New build lights fans on but no video signal
Forum Homebuilt Systems : New System Build - [Solved] New build lights fans on but no video signal
Best answer from shortstuff_mt.
I just built a new system and when I turn it on the fans and light work but no video signal any thoughts i read the boot post and tryed most of it. I am lost was hopingthis was goining to work first try now dont know what to do.. Any help would be great
MOBO Asus M4A79XTD EVO AMD 955 BE Muskin Ram 996657 1600 2x2gb. sapphire 4870 1gb
Your problem is VERY common. In fact, that's why the checklist was created in the first place. You have to do much more than try a few things. The chances are very good that you'll find the resolution to your problem if you actually take the time to perform EVERY step in the checklist. #2 on the checklist is the most common problem.
You're just shooting from the hip until you install a system speaker.
What PSU do you have? Do you have both power connectors plugged into your GPU?
Sponsored Links
"when I turn it on the fans and light work but no video signal "
so the fans are spinning right?
video signal, did you plug your monitor cable in?
read this.
http://www.tomshardware.com/forum/ [...] t-problems
------------------------------ You can select me as Best Answer
e6400 oc'd 3.2ghz,CCF cooler
3870x2, p5k/epu
750watts psu, antec 900
Reply to overshocks
Sorry for the lack of discription. I have read the post your refering to and as far as I can tell it none of those things are my problem. Yes its plugged in to the monitor I am using the VGA adapter untill I get a new monitor but monitor is good was using on old system untill now. The fans are spinning even on the graphics card. The lights are all on. But monitor says no signal and I tryed both DVI outs on card. I have reseated card and moved and tryed different memory configarations. Reseated cpu. But still no luck I am lost and guessing graphics card is shoot. I dont have a speaker in the case so no beeps to trouble shoot with. Open to all suggestions thank in advance Shawn
Reply to Hags
Best answer
Message edited by shortstuff_mt on 09-24-2009 at 07:11:33 AM
Reply to shortstuff_mt
what does your monitor say just no signal?
is this a new video card meaning you never used it before (so you dont know it works or not)?
3870x2, p5k/epu
Reply to overshocks
Funny..when i told him to refer to the guide.. :( shortstuff gets best answer
Message quoted 1 times
Message edited by overshocks on 09-24-2009 at 07:23:33 AM
3870x2, p5k/epu
Reply to overshocks
Shortstuff I dumb and wasnt sure about #2 and dissmised it and that was the problem. Thank you all for helping a dumby like me
Reply to Hags
You have issues.
Message edited by shortstuff_mt on 09-24-2009 at 06:10:05 PM
There are 1175 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
