Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] POWER PROBLEM!!!!
Forum Homebuilt Systems : New System Build - [Solved] POWER PROBLEM!!!!
Best answer from Proximon.
OK, just got my system put together and have had it running for a couple weeks now. My big problem is when i shut down my PC and then start it back up, it will start for a couple seconds (lights come one, fans spin, etc.) then it shuts it self off. A couple seconds later, it will turn itself back on and repeat the process, After doing that a couple times, it will finaly stay on and boot like normal. I am really scared that this power cycle thing is hurting my hardware. Does anyone know what could cause this and how i can fix it :??: Any info is extremely appreciated!!!!!!!!!!
------------------------------ Intel Q9550 at stock
Arctic Freezer 7 Pro
Gigabyte GA-EX38-DS4
XFX ATI Radeon 4890
I think you could try a BIOS update at this point. There is SOME risk involved so be very careful to follow instructions carefully. This is only done when you have a moderately serious issue.
You will find newer versions of your BIOS and detailed instructions here:
http://www.gigabyte.com.tw/Support [...] #anchor_os
Sponsored Links
sorry, the specs at the bottom are wrong, the new ones are what have now
Reply to Vaxorth25
This is a feature of your BIOS. It indicates that some setting in the BIOS is failing and it's resetting to fix it.
The usual suspect is the DRAM voltages and frequency and timings.
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
Intel Q9550 @stock
Arctic Frezzer 7 Pro
Gigabyte GA-EX38-DS4 Motherboard
XFX ATI Radeon 4890
Patriot Viper RAM @ 1066
OCZ MODXSTREAM 700W PSU
WD 500 GB green HD
Windows 7
Reply to Vaxorth25
Ok, how would i change this to stop it, would you know how?
Reply to Vaxorth25
I can make some guesses.
Which one of these is yours? be certain you have the exact model.
http://www.newegg.com/Product/Prod [...] 20x%202GB)
Reply to Proximon
So you should go into your BIOS and Just look to see what the DRAM frequency, timings, and voltage are at.
If the frequency is 1066 (may say 533)or lower, and the timings are 5-5-5-15 or greater, and the voltage is 2.1V, the settings are probably OK.
Reply to Proximon
ok i have the frequency and the timings down i just can't find where the voltage if for the RAM
Reply to Vaxorth25
would you know where in a Gigabyte GA-EX38-DS4 that the voltage timings are found?
Reply to Vaxorth25
On the M.I.T page I think you have to select Manual for the system voltage control. then it should appear.
Reply to Proximon
OK, i have found the DDR2 Voltage levels but i don't know what to set it to. the levels increase by .5's
Reply to Vaxorth25
Try asking Patriot support, I bet they would know.
Reply to scatrdfew
Hopefully that is .05V not .5V. If you read over what I have already written you will find the correct voltage.
Reply to Proximon
I have all of the RAM Settings applied but it is still doing it what else could cause it?
Reply to Vaxorth25
I'm not sure, I don't have the manual and I don't know where in the BIOS you would see the version. I'm sorry if I'm not good with all the the BIOS stuff, this is my fist build and I just want to have a strong and stable system. If you know where it is at, I can probably get it for you.
Reply to Vaxorth25
It's displayed at start up, but may go by fast. I thin k you can get it from inside windows though....
yes, CPU-Z will tell you.
CPU-Z
just fire it up and look at the mainboard tab.
Reply to Proximon
OK, found it, the Version is F2, that what it says anyways
Reply to Vaxorth25
Best answer
Reply to Proximon
I will be getting a floppy drive from a friend, i will tell you if i get it updated tomarrow.
I haven't updated a BIOS before but I think i can do it.
Reply to Vaxorth25
I got the BIOS Updated all the way to the F6c Beta and it is still doing it........I'm just completely confused. Are there any other factors that could cause this?
Reply to Vaxorth25
Sure, let's back up and go at this a bit more carefully.
Since you marked this one as solved, start a new thread.
Use this guide to help you:
http://www.tomshardware.com/forum/ [...] leshooting
Be sure to put in ALL the component info.
Then link the new thread here so we can jump to it.
Reply to Proximon
There are 1276 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
