Hi, I am currently having a problem with my fan speeds. I have an Asus m4a87td Evo motherboard. I have disabled cool n' quiet and tried to disable Qfan (but I dont believe it is actually disabled)
My fans recently would run at around 3000rpm, whenever I would run a stress test they would peak as high as 7000rpm but I could never get them that high manually. I have also installed speedfan and even though I have control of my fans, I do not have 100% control.
I have recently installed a water cooler and my fans now think that 100% is 1500rpm. If I reduce the fan speed to 50% it will cut to 750rpm but I cannot get it to go higher then 1500rpm. I believe there is some type of software that is controlling what is considered 'max' speed and I only get to work within its parameters.
I do not want to run my fans at 7000rpm because that would be way to noisy but I don't like the idea of not having 100% control over them, I am going to overclock soon and would like to be able to turn up my fans when necessary.
