Ok so I'm building my system,
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W
2 5870's cross fire
8gb mushkin blackline
MSI f90 FX gd70 Mobo
standard 300 cg seagate barracuda HD
Standard dcd rw recordable drive
I need to know if this power supply is enough to get full use of the system, consider there is no or minimal (like 5-10 %) overclocking on the processor and the ram running at 1600 if i'll be able to at 1.9 which people claim i can
http://www.newegg.com/Product/Product.aspx?Item=N82E16817815002
Also in the future I was thinking of an attempt to use my bfg 8800gtx as a physics card, i messed up in my calculations (2 pci express connector X 3 cards = six needed) and this power supply only has 4, however I could use something like 2 of these http://www.newegg.com/Product/Product.aspx?Item=N82E16812887001
I already made the order overlooking the damned pci connectors, and from what i've read It should be ok. However can someone who really understands power supplies tell me what margin i'm at, if it's not enough, if it's just barely enough, or if I'm in the green with this setup
Thanks a billions in advance
2 5870's cross fire
