My laptop a Dell Studio 1558 was running great, and I decided I wanted a faster boot. So I went with a 60gb Corsair Nova 2 SSD.
I did all the usual before I go into my laptop, took out battery and plug, discharged static electricity on me and laptop, and pulled the HD, then put the new one in.
I then went into the Bios screen, the new SSD was recognized, I changed the HD mode to AHCI and I put my Windows 7 Disk in and proceeded to install.
The installation was about 20 seconds in and the computer shut off.
I repeated and computer shut off a little earlier in installation.
I then went into the Bios and computer shut down while I was in the bios screen.
At this point I put my old HD back in, it booted fine. Got into windows with no problems, did some research for 30 minutes or so and then restarted.
Now with my old HD in, the computer shuts down in the bios screen or while loading windows...HOWEVER sometimes it will get into Windows, and if Windows actually loads; it does not shut off.
I put the SSD back just to see....same issue as before (with the SSD in it shuts off much quicker than with the traditional HD).
Here is what I have tried and checked.
-CPU temp stays less than 35c under loads. (I put arctic silver 5 on the processor about a month ago)
-GPU has no sensor, but is under the same heat sink also with ac5.
-SSD works fine inside a different laptop
-My HDD works fine if it gets into windows (which is 1 in 3 times)
-Updated the Bios via Dells Website
-Reset Cmos
-Replaced Memory with known working and tested memory.
-Ran with only battery, only ac adapter, alternate ac adapter, and both battery and adapter
-Inside of laptop is dust free
The crazy thing about this is when it loads into windows, it does not shut off. Has anyone ever heard of anything like this or can anyone give me some troubleshooting ideas?
Feel free to recommend whatever you can think of....I diagnose and repair hardware issues for an IT company, I am perfectly capable of breaking down the computer 100% and probably will do that when I'm done with this post. I don't believe I will find any loose cables or anything, as the computer was working fine before I swapped this out....
-Reset Cmos
