Purevideo problem
Forum Graphic & Displays : Graphics Cards - Purevideo problem
I just bought a new 9800GT, (don't need a extremely powerful card) and though everything so far is working find I am having problems with purevideo. I use powerDVD and when I play an movie the bottom half of the screen looks as if its corrupted video with green, blue and yellow image tearing and flickering. If I reinstall the previous card, which btw was a ATI no problem all video is fine. This happens regardless what driver I use. All previous drivers are completely removed so I'm basically ruling that possible problem out. Any ideas what could be causing the problem and how to fix it?
Sponsored Links
Triple check that you download the right driver per your new 9800GT card. Make sure your downloading it for the right Operating system. Check if you're Operating system is 32bit or 64 bit, and make sure its the right OS...
Message edited by pluke the 2 on 10-10-2009 at 12:20:33 AM
Reply to pluke the 2
All check and correct. I'm using driver 186.18 as the latest driver was causing problems all around. If I play a game there is no problem but when I play a movie, problem. Odd enough about half the time it only does that when I open powerDVD and try to find my way through the menu the flickering occurs but after a few moments when playing a scene it eventually goes away.
Reply to sdf
What happens if you use a better player like VLC or GOM?
------------------------------ The voice of REASON
Do NOT feed the TROLLS!
Always a DEMON!
Reply to 4745454b
Not sure what those are.
Reply to sdf
Media players. Better then PowerDVD or Nero or WMP. GOM looks better, but I like the menus/look of VLC. Download one and see if the problem continues.
Always a DEMON!
Reply to 4745454b
Was just asking for the name of those media players, so just did a search instead of asking in another post. I'll try them out and report what happens.
Reply to sdf
Sorry, as you found out those are the names. Try one or both, might fix the issue. It could also be an issue with the card or the files if it only happens on certain ones or types.
Always a DEMON!
Reply to 4745454b
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Purevideo problem
There are 513 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
