Need advice on i5 gaming system($1000)
Last response: in Systems
September 25, 2009 11:43:59 AM
Hi guys,
i am buying a new system this week and need your advice. I have short listed the components , just wondering if they are all compatible and if there r any better options. please help guys.
proc: i5
mobo: gygabyte Gigabyte GA-P55M-UD2
RAM: 4 gb, not decided, not sure which r compatible with 1156, please suggest from corsair, transend, kingston only these r available near my place.
graphics : Sapphire HD 4850 512MB or 4870 (will decide if any money is left after other comps)
monitor: Samsung 21.5" P2250 LCD.
case: Coolermaster Elite 334
smps : Tagan Stone Rock TG600-U37 600Watts or corsair vx550
HDD: WDC 500GB .
I have a dvd drive and will pick up any good keyboard n mouse combo for $20.
so what do u think guys. is the tagan smps good enough ?
September 25, 2009 11:52:02 AM
What country are you in, and what is your screen resolution ?
m
l
September 25, 2009 11:54:30 AM
I am from India and I want to get a lcd with screen resolution of 1920X1080.
m
l
September 25, 2009 12:23:55 PM
Everything looks good ...I would go with the Corsair psu.
m
l
September 25, 2009 12:32:07 PM
could u suggest which RAM I should use.
m
l
September 25, 2009 12:34:02 PM
Corsair DDR3 Dual channel....low voltage if possible. Nothing that is rated over 1.65V
m
l
September 25, 2009 12:55:40 PM
thanks for your reply Why_Me..
m
l
September 25, 2009 2:10:01 PM
guys is the stock heatsink enough I OC just a little bit ?
m
l
