Question about the stock cooling on the NZXT Guardian 921
  • Power Supplies
  • Cooling
  • Computer
  • Cases
  • Components
Last response: in Components
December 14, 2009 12:31:16 AM
Does anyone own this case? How is the cooling?
My computer usage varies from day to day. Some days I do not use it and other days it is on the entire day.
I heard that the cooling was good for this case, but I just want to make sure.
Does anyone else have suggestions about other good cases around $80?
Thanks!
More about : question stock cooling nzxt guardian 921
December 21, 2009 2:15:51 AM
I think the more important question for you is, how important is the stock cooling of the CPU you plan to get? If you're going to OC, a third-party cooler is a must. Once you think your CPU and GPU cooling is ok, you can then now consider the case and its own cooling prowess.
m
l
December 23, 2009 7:01:12 AM
i had a look at the case. it looks the like the best case ever, but its small, and may not cool enough for your needs.
what are your components, and what kinda CPU-cooler are u using?
m
l
