Before I start with my problem I want to clear up that I am not an expert on monitor nor an expert on computer so please bear with me.
I've just purchased a Mitsubishi Diamond Pro 2070SB(22" ) from Dell(got a great deal ).
I've set the resolution and refresh rate at 1600X1200@85Hz
and I am using ATI 8500 graphic card.
The problem is that there seems to be flashing/blurrying on the upper left corner and lower right corner. I don't know if it's some settings that I have to adjust.. or did I get a defective monitor or am I just being anal?
I guess the flashing is not really noticable unless you watch it carefully but because its flashing, it seems to make the two corners blurry. I really don't want to bother sending and waiting to recieve another monitor unless this is an defect for sure.
I want to thank in advance for your replys so, THANK YOU ^^.
