Hi
I'm experiencing temperature problems with my video card. I have 2x GTX 470 running in SLI. According to Msi Afterburner GPU1 is idling at 80-90 degrees on auto fan speed (about 64%).
When I play games the fan speed goes up to 90-100% and the temperature is between 90-105degrees.
I've already managed to burn one card. So It's about time I do something about this.
I have a Fatal1ty case with 2 "Scythe Gentle Typhoon92mm 2150rpm" as front fans blowing air in (full load), 1 "Scythe Gentle Typhoon120mm 1150rpm" back fan pushing air out (full load) and also a "Noctua NF-B9 Silent Case Fan 92mm 1600rpm" in the case door. I have tried switching this last fan to both pushing air out and blowing in. Doesn't seem to make any difference on the vide cards though.
As I have a "Gigabyte GA-X58A-UD5" motherboard, the second video card is right below the first one which probably contributes to the high temps. But I keep my hopes up on that I can do something about the airflow to lover my temps.
For the CPU I have the Noctua NH-C12P.
I have thought of 2 options this far.
1. Removing the 3 HDD bay which is "blocking" the front fans and move the harddrives to the 3,5 bays instead.
2. Make another hole, but in top of the case with another 120mm fan pushing air out.
What do you guys think? Have any ideas and/or do you think the above options would improve anything?
Thanks in advance
Sisu
| PSU - Antec TruePower Quattro 850W | Motherboard - Gigabyte GA-X58A-UD5 | Ram - Corsair 6gb (3*2048mb) 1600mhz XmS3 | Processor - Intel i7 930 2,8ghz | Video - Gigabyte 2 * GTX470 SOC (SLI) | Sound-card - Asus Xonar d2x (pcie) | HDD\'s - 2* 80gb ssd Intel X25M G2 (RAID0), WD caviar black 640gb sata/300 32mb | LG DVD DL SATA | OS - Win7 Enterprise(64-bit)
Thanks in advance
Sisu
