Figured I would make a new thread on this since it is a different issue, I will be getting this graphics card in about a month and this power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150433
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
Now the issue is this
http://121.33.239.180/sell/pic/temp/asus-sony-p4sd-vl-front.jpg
As you can see behind the main 20 pin lead, is a small 3 pin, I have tried unplugging this and turning my computer on but it says Fan abnormality, even though all of my computer fans are working.
The issue is getting a new power supply that will support my 4650 and have that 3 pin hookup, as the fan is plugged into the 4 pin to the left of the CPU mount, and this 3 pin directly above my 20 pin lead is connected directly from my power supply.
I am at a loss for what to do, I have considered getting the new PSU and just plugging it into my gfx card and leaving the old one plugged into everything else, but I don't know if that is viable or smart.
