Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > Methods to calculate power consumption of multi core processor
Forum CPU & Components : CPUs Methods to calculate power consumption of multi core processor
Hi.. iam looking for a method or device or software which can calculate the power consumption of a multicore processor... and if a device or software exists.. how much would it cost me.... please do reply as soon as possible..
thank you ...
Reply to vamshi999
There not really a device or software program that can measure power consumption to a single item (like a cpu) for the general market that im aware of. There is however a way to see your overall system power consumption called a "kill a watt"
http://www.amazon.com/P3-Internati [...] 277&sr=8-1
------------------------------ http://img693.imageshack.us/img693/4272/sfolding6.gif <-- CLick the banner!
Reply to warmon6
For estimating power need for PSU to power system, there a psu calculator called "eXtreme Power Supply Calculator Lite v2.5" http://www.amazon.com/P3-Internati [...] 277&sr=8-1
Although this is estimated power consumption and not actual power you'll be consuming.
Message edited by warmon6 on 12-14-2009 at 08:24:28 PM
Reply to warmon6
i found this link http://www.xbitlabs.com/articles/c [...] ut_11.html .... i need something like this.. please correct me if i am wrong... whether i am looking at the right one or nor..
Reply to vamshi999
Well first i have heard of a program that can measure power consumption to a single item. although the web site that they lead you to that has the program is in a language i cant read.... So i cant say how well it works.
Message quoted 1 times
Message edited by warmon6 on 12-14-2009 at 08:53:28 PM
Reply to warmon6
this is the translated page...http://translate.google.com/translate?js=y&prev=_t&hl=en&ie=UTF-8&layout=1&eotf=1&u=http%3A%2F%2Fwww.testmem.nm.ru%2Fsnm.htm&sl=ru&tl=en ... sorry about the last page..
Reply to vamshi999
I also would like to know how it works. As far as I know, there are no sensors that such a utility could monitor to calculate power consumption.
I use a clamp-on ammeter to measure the current flowing through the yellow wires (12 volt) in the CPU power cable. Times 12 volts gives me watts into the motherboard power regulator.
Reply to jsc
I usually just read the spec sheet for the particular processor, and pretty much just go with that. :)
Reply to jitpublisher
it seems there are some specific methods to calculate the power consumed by a multiprocessor..... the power consumption varies with the execution of same program in different ways...
Reply to vamshi999
Or I just estimate 10 amps (120 watts) for an OC'd quad core CPU.
Reply to jsc
can you explain me ...how to do that ?
Reply to vamshi999
There are 1770 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What case should i get? Between these 3 with my build?
By amuffin, 1 hour ago:
They will all work, but I would grab the HAF 912. This is because I've owned the 912 and...
Best offers
Top experts
