hi,
am stuck in a bit of a dilemma early this year spent bout £300 on upgrades antec 300 case, earthwatts 500w psu, 4gb ddr2 6400 800mhz ram and a fancy gtx 260 golden sample and took the rest of components out of the stupid vostro 200 slim tower damm them half heights/low profiles.
So i have the old slim case, 2gb 677mhz ram, 250w psu, and the low profile x1300 remaining and plan on buying a few components and will put the stupid dell designed mobo that does not allow for quad core due to the bios and something to do with power phase back in the case and give it to my lovely mummy for xmas
that leaves me without a mobo al keep the E6750 and buy her a lower spec cpu, but i like physx currently i have only the one game mirrors edge that struggles with eye candy at max gaming at 1680 x 1050 res the frame rate is terrible on the gtx 260, non physix games my card is beautiful
the problem is i have my eye on a nforce 680i LT SLI mobo and a GREEN/eco/low power 9800gt firstly:
will the earthwatts 500w be enough to power my gtx 260 with a 9800gt not sure 512mb or 1gb green version (no additional power required) as a dedicated physx processor? with
1 hdd (another internal hdd in the future)
1 dvd drive
4gb ram
e6750
is the 9800 gt green a good choice for the physx?
or would you recommend different components?
ps just want a cheap solution to get them frames up on them physx games that take my fancy over the next year or so, hopefully them socket 775 quads will be cheaper few months down the line, or until i can afford the i5 i7 ddr3 dx 11 card
cheers
1 dvd drive
4gb ram
e6750
cheers
