Power switch issue
Forum Homebuilt Systems : New System Build - Power switch issue
I have this Dell Power button and I'm lots with connection since it have 6 cables, can any one tell me by looking at the picture which cable I need to connect, I was trying random with not very good result.
http://i12.photobucket.com/albums/a216/wieslawg/DSCF0979.jpg
http://i12.photobucket.com/albums/a216/wieslawg/DSCF0977.jpg
Sponsored Links
I see a button and an LED and 6 wires Is this correct ?
Is there another button for the reset somewhere ?
Is there a separate LED for the hard drive ?
The way I see it if you only have the power buttn and the power led you should have only 4 wires
Is there any writing on the wire or the connector at the other end ?
If not you may need a volt/ohm meter to trace out the wires from one end to either the switch or the button
Reply to status1
There was no restart button on xps 710, and there are 6 LED but they are on seperate board, only power and power ligh is on this one, there is no writing on wire and don't have voltmeter, butI'll try to get one
Reply to morfinel
Could we see the other ends of these wires? What connectors are on them?
Reply to Twoboxer
On the end there are pin that were in one plug simmilar like the one on the picture white but could be plugged, that was connected to bigger board which then was conected to motherboard with pin that only dell use.
Reply to morfinel
Tom's Hardware > Forum > Homebuilt Systems > New System Build > Power switch issue
There are 649 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
