Hello,
Last week my power supply fan started to make noise. Seeing how the power supply is now well over 4 years old i figured I would get a new one and not just wire in a new fan. The first power supply was a Raidmax 630 something or other. After installing it I noticed that the Graphics stutter/freeze for about a millisecond or 2 every second. When watching a movie or playing a game was when I first noticed it but then started to see it in everything from, while moving a window around then screens or even just the mouse pointer. At first I didn't think this could be the power supply. I removed everything and cleaned all the dust off with a can of air, cleaned all contacts with contact cleaner. Retried and system was still doing it. Wiped drive and reinstalled windows. Tried both windows XP and windows 7 both did same thing. After trying everything I could think of I plugged old power supply a 600 watt Ultra X Finity and they stutter was gone. Returned Raidmax power supply and got a Antec 650 Earthwatts with 3 Rails. Installed new power supply and found stuttering screen has come back.
Any ideas would be helpful. Thanks
Current system Specs
Window 7 64 Bit
Gigabite MB GA-P35-S3G
Intel Core2Quad Q9450
Two 2GB Corsair 6400 (4GB total)
XFX 8800 GT (new Power supply had two 6 pin connectors. Tried both)
Raptor 300GB sata 10,000rpm drive (system drive)
Two WD 1TB sata storage drives. (disconnected and problem still there)
LG BD Sata optical Drive
Window 7 64 Bit
