Yes No
Ads
Tom's Hardware > Forum > Overclocking > CPUs > [Solved] Beginner overclocking help
Forum Overclocking : CPUs [Solved] Beginner overclocking help
Best answer from HostileDonut.
I have worked my way from 3.2 Ghz finding a stable clock on every .5 of multiplier I add but now I'm stuck at 3.7 Ghz. It boots up to 3.7 find and runs prime 95 for 1 or 2 hours but then freezes but doesn't crash. http://i.imgur.com/peUrx.png
Reply to laptop4079
Best answer
Your voltage is insane. AMD says 1.5v maximum. What is the heat? What HSF? Motherboard, PSU? Whole system please. It could be that you are running the CPU at that voltage, which is producing more heat (more voltage = more heat) making the CPU shut itself off or stop the program. What are your BIOS settings?
Reply to HostileDonut
Although really, keep running that CPU at that voltage, it will die. Soon.
On idle it runs around 95 F and under load it goes up to 120-130 F. I have a gigabyte ga-ma790xt-ud4f motherboard, psu is a 600 w corsair and 4gb of cheap "Super Talent" ram That's everything I have changed. http://i.imgur.com/4hM6x.jpg
Message edited by laptop4079 on 12-28-2011 at 11:14:06 PM
Reply to laptop4079
By putting the voltage on the RAM a little bit higher, you may reach a better OC. Just like, .1v though. CHANGE THE CPU VOLTAGE AS SOON AS POSSIBLE! YOU WILL KILL THE CHIP! :non: Kepp the voltage stock, and try to boot from there. When it crashes, raise it a little. But don't go past 1.45v. (.1v past stock) Now, if you get a crash, try raising that RAM voltage ONLY slightly. See if you get in to windows. Shoot for 3.8Ghz. Get back to me with what happens and how far you can get. Also, what are your temps in Celsius?
In celsius idle is 35 to 37 under load it's 48-53 and I reset all my settings to default.
Message edited by laptop4079 on 12-28-2011 at 11:37:46 PM
Reply to laptop4079
Ok I can boot into windows on stock voltage but as soon as I ran prime 95 it bsod instantly. Even after raising my cpu voltage to 1.45 and my ram to 1.7 it only lasted 30 seconds.
Reply to laptop4079
Your CPU is also a C2 revision, which means it will not OC to 4Ghz very easily. You would be lucky if you got it there. Can you get it stable at 3.7Ghz? That is where a C2 chip will generally be at. 3.7-3.9Ghz. Try these settings: Auto voltage (MAKE SURE IT DOES NOT PASS 1.46V!), 2100Mhz NB, 1.7v memory, and that may do it. Monitor heat, voltage spikes, and VOLTAGE! Auto generally overvolts the CPU, but when I OCed yesterday (hit 4.4Ghz on auto easily) it actually was stable with a lower voltage that a fixed voltage I used.
In my bios I can't manually set the memory voltage and leave the rest auto but I set the nb to 2100 and not much changed.
Reply to laptop4079
Can you get to 3.7Ghz stable? If not, try 3.6Ghz. That looks like a pretty decent board. I don't know why it won't OC very well. Turn off Cool N Quite if you can too.
Message edited by HostileDonut on 12-29-2011 at 02:49:09 AM
Why can't you manually set the memory voltage?
I can normally set the voltage but when I do i have to swich it from auto to manual on all the other things.
Reply to laptop4079
Oh, well then keep the RAM at stock voltages. Tell me if you can get 3.7 or 3.6Ghz stable.
Ok Should I be using the ratio multiplier or the clock control? And when I kept everything on auto and dropped the cpu frequency to 3.6 but it still crashes as soon as I hit start on prime 95. Here are the settings I used
http://imgur.com/TJRb7.jpg
Message edited by laptop4079 on 12-29-2011 at 07:11:35 AM
Reply to laptop4079
Try OCCT. http://www.ocbase.com/perestroika_ [...] p?Download My Prime95 crashed after a while (about 5 hours) but the system didn't crash. My multiplier was also fluctuating. It was really weird, but when I used OCCT, my multiplier stayed at 44, and I got the whole 6.5 hours I set it for. Prime95 was interfering I think. It may be doing the same to your system. Also, using the multiplier is great, but you can also use the FSB. When using the FSB, tune your memory settings down. Meaning, run your memory slower, and the FSB increase can bring the memory speed up a little bit along with the CPU.
So, use OCCT, FSB a little, and tune the memory down a bit.
I doubt it but I have access to a amd athlon ii x4 635 2.9 Ghz, would that offer any more power/overclocking ability?
Reply to laptop4079
Did you use OCCT? The Athlon may yield better results. But keep in mind, it has a locked multiplier. Set your RAM speed down and then adjust the FSB.
Yes I tried OCCT i've had that installed for a while now I just never used it :D It it lasted an hour but still bsod
Reply to laptop4079
Hm. Pop in the Athlon and see what you can get with that. Maybe for some weird reason your chip just doesn't like being overclocked.
Will do give me a few hours to get if my friend and I'll post back with results? Where should I start off at and what clocks are reasonable? http://i.imgur.com/ysA7m.png
Everything here is stock.
Message edited by laptop4079 on 12-30-2011 at 03:42:02 AM
Reply to laptop4079
Core voltage at 2.144volts? That was a insane voltage even for something like a 130nm athlonxp cpu.
Reply to need4speeds
That's directly from a HP pavilion desktop with just a stock cooler nothing has been changed.
Reply to laptop4079
The max voltage for that CPU is 1.25v. Either that CPU-Z is not reading the voltage correctly, or I am very surprised that CPU is not on fire. CHANGE IT QUICK! Check the BIOS or manually set the voltage! That is insane! For clocks, go by changing the FSB to 205, 210, 215, 220, etc. Also, change the memory down to 667, and if you pass 800Mhz on the memory with an initial setting of 667mhz, change it down t 533. What cooler again?
I can't change it since it's a HP computer and the bios is locked. and it's on the stock cooler from HP
Reply to laptop4079
Well, you can't overclock an HP anyway. Take the Athlon and put it into your machine.
When I put the phenom into the hp it wouldn't boot past the windows loading screen so that idea is bust.
Reply to laptop4079
That is strange. ;/ Hm. Well, you can try tuning the FSB instead of the multiplier. That is my best idea.
Try another cpu monitor, a different one to confirm the voltage. It might be a cpu-z glitch too.
-I would do some troubleshooting, and fast before it cooks itself. If cpu-z is telling you the truth it might already be cooked.
Message edited by need4speeds on 12-31-2011 at 03:26:48 AM
i found this because my AMD Phenom ii x4 830 is at 2.144 voltage too! also an HP desktop! im like WTFFFF!!!
Reply to thesofah
There are 1717 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Does a computer NEED ram?
By Motopsychojdn, 46 minutes ago:
A Pc will not function without ram, simple as, can you post the model/make of your Pc and...
Best offers
Top experts
