Tom's Hardware > Forum > Homebuilt Systems > New System Build > New build problem with screen resolution
Forum Homebuilt Systems : New System Build - New build problem with screen resolution
Hi everyone,
My friend has just built himself a new pc today and when he has installed windows and started to use his pc it is massivley noticeable that the resolution is all wrong.
The pc states that the resolution is 1920x1080 but this cannot be right. The monitor is a samsung sync master 2333hd which works great for me.
He has an I5 cpu and Geforce GTX 260 GPU both brand new.
Any one got any ideas hes really gutted about this.......
Thanks
Kev
Sponsored Links
video drivers?
monitor scaling?
where does it state its at 1920 x 1080?
and what Hz is the screen refresh set to ? It should be at 60 Hz
Reply to Outlander_04
Latest video drivers installed.
It states in the properties screen in windows its at 1920x1080 and also when you turn the tv on it comes up in the left hand corner of the screen.
Reply to kev3kev3
then in the monitors menu and see its set to 16:10 widescreen
and make sure the refresh rate is 60 Hz in properties
Message edited by Outlander_04 on 09-27-2009 at 12:39:27 AM
Make sure to get MONITOR drivers, not just video drivers. MONITOR drivers will only show and allow access to the resolutions it supports.
and FYI,
that monitor has a native resolution of 1920x1080 and it is a 16:9 monitor!!!
http://www.samsung.com/ph/consumer [...] 3CFUKFV/ZA
Reply to photonboy
Only does 1920x1080?
Are you using the DVI input?
There are two ways to hook up video to some modern monitors. The normal way is to use a PC input (VGA, DVI and sometimes HDMI). The second way treats it more like an HDTV, usually HDMI.
Depending on your choise of monitor inputs you are either putting out PC data or VIDEO data. For example, if you hook up a Cable box to an HDTV using HDMI it puts out a single video output such as 1080p. If you are putting out HDMI-Video at 1080p you are LOCKED to a constant 1920x1080 resolution. You may even have some overscanning or other scaling issues to deal with. You absolutely do NOT want to use this for a PC (though it's nice to have for a PS3 or other device as the PS3 puts out Video).
My dad can watch high-def BluRay rips (mine of course. cough.) using his laptop hooked up to his HDTV via HDMI. This is a VIDEO signal and it took a little tweaking at first to get the overscan setup (through the NVidia Control Panel). In theory I could have used the PC-VGA input that the TV had but it was limited to 1366x768 and it's a pain to remove the cable. VGA has no HDCP support meaning it can't support BluRay from a PC. (I also had to toggle the Audio to "HDMI" which turned off the laptop speakers and sent all the audio out the HDMI cable as a PCM Stereo signl.) This looked and sounded amazing though.
There is:
HDMI-PC, and
HDMI-Video
You need to ensure that you are using one of the PC inputs. You'll know if you get a choice of multiple screen resolutions, usually 800x600 up to 1920x1080.
You should be using the DVI input.
Message edited by photonboy on 09-27-2009 at 03:49:36 AM
Reply to photonboy
kev3kev3 wrote :
only does 16:9 widescreen
my mistake .... just so long as it isnt set to 4:5 or 3:4
There are 603 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
