Archived from groups: comp.sys.laptops (More info?)
Currently I am using a 1 year old laptop to play music to my home theater
system. When I am running on battery power, I get a perfect signal to the
receiver. However, when I plug the laptop into the wall I get a low pitch
hum through all the speakers. I have researched the problem extensively but
even when the audio cable is far away from any power cable (including all my
speaker wires to and from the receiver, I still get the hum). I was
thinking that if I had an optical connection from my laptop to the receiver
I wouldn't get any feedback. Problem is, does anyone make a PCMCIA
soundcard with an optical output or perhaps even a digital shielded coaxil
output? I have read other newsgroups with links for cheaper USB soundcards
with optical output but they have been dead ends. If anyone has any ideas
or knows where I could find what I am looking for it would greatly help.
Josh
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
A PC Card (and that is the correct terminology, "PCMCIA" should no
longer be used) is not the answer.
What you want is an external USB sound card. That should solve your
problem. Several firms make them, Creative has several models, from
about $40 to about $200.
> Josh
>Josh
There are ring magnets that will stop that hum. They clamp over the
power cable right before the plug goes into the notebook. I have over
a dozen video and sound cables that all came with these magets.
You might look at RMEs Hmaerfall DSP series of cards:
http://www.rme-audio.com but that might be a bit of an overkill for your
needs.
Yor problem sounds like ground loop that can be solved by disconecting the
ground conection of notebooks power cable (a lot of people who use notebooks
for music production do this).
"Josh Walrath" <puckdrop87@cbcast.com> wrote in message
news:40b6a065$1_3@corp.newsgroups.com...
but
my
receiver
soundcards
> Josh
They are not magnets, they are ferrite beads, which act like chokes
(large inductors). They may or may not stop the noise that he is
seeing, they are primarily effective against HIGH frequency emissions
rather than aginst what sounds like 60Hz "hum", but it's worth a try.
>>Josh
Hum is usually caused by a ground loop. An opto-isolator would solve this
but a cheaper solution woud be an isolation transformer on the audio lines.
Radio Shack used to carry one. Sometimes, just disconnecting the shield lead
on the laptop audio out will work.
Terry
"Barry Watzman" <WatzmanNOSPAM@neo.rr.com> wrote in message
news:40B8A4C3.2070100@neo.rr.com...
theater
the
pitch
but
all my
receiver
coaxil
soundcards
ideas
> >>Josh
