Water cooling system
Forum Homebuilt Systems : General Homebuilt - Water cooling system
I am installing a radiator (XSPC) on my computer for the water cooling system. Does it matter which is the in or out for the water flow on the radiator.
Sponsored Links
Which rad? For 90% of the rads it shouldn't matter.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
I have an XSPC radiator. I am installing Swiftech Apogee drive series self powered waterblock with integrated pump. I may have it hooked up wrong as it does not pump. It sounds like it is trying, but does nothing. Can you help?
Reply to joan_trc
^I'm talking about rad size. I recommend you moving this thread to the "Coolers and Heatsink" section.
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Water cooling system
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
