Phenom II 960T (unlocked to x6, no other changes)
2x Radeon 6850(11.12 ccc)
8GB Hyperx ddr3 1600
ASRock 870 Extreme 3 R2.0
1TB Seagate 6.0Gbps
750w Antec psu
screen resolution 1980x1080
1) Just ran prime95 for an hour. Temps were around 66C. Not sure if thats to high. Idle at around 36C using speedfan.
2) In Battlefield 3(multiplayer) i'll be getting about 50-60 fps and it will drop to around 10 and couple times completely freezing but come back after a few seconds. Doesnt seem to have issues with Skyrim. Didnt try any other games yet though.
3) Could bad cores do that even though it didnt give errors during the prime tests? I did no other changes in the bios.
4) And also....I originally had a 870 extreme3 R1.0 but dimm slots and ethernet port were going bad so I replaced it with the R2.0. I didnt do a refresh windows install, instead just installed the needed usb and lan drivers. Would that be a case for the problem?
1TB Seagate 6.0Gbps
750w Antec psu
