I'm hoping this will be a pretty darn good build. With everything the price is $1,673 with the 2 radeon cards. Its about $20 or so more for the 1 gtx 285. If any of you have any other advice on hardware changes plz don't hold back. This is my 1st big build so I am a noob.
Other thoughts:
CPU/mobo are combo
Case/PSU are combo
Velociraptro/OS are combo
I have thought about going over to an intel build but have been using AMD for over 6 years and just love them, so its a preference thing for me. And as for the raid 0 setup I know it will be faster but I want the veloci for the performance and than the WD caviar blue for backup. I have alot of important college documents I must keep when I reformat.
BTW thankyou for such a quick reply!
Understand... I still say go with the Samsung Spinpoint F3's not in RAID0. These are pretty much as fast or faster than the VRaptor for a lot less money. It will give you more storage without any loss of speed.
would 2 samsung spinpoint f3's be better performance than say 2 wd caviar black 1tb's?
also for the xfx 5870, if I get the 2 spinpoint f3's that will give me some breathing room to get the xfx 5870, also in a month or 2 when more money comes around would if be a wise choice to pick another one of these up and crossfire them?
Also I'm getting the vista 64bit OEM. If I do get another one of these cards will it void the oem license?
Message edited by shaggy2k7 on 09-28-2009 at 02:00:58 AM
Yes, the Samsung would give you better performance.
Picking up a second 5870 will give you the ability to max every game, so yes it would be worth it.... Note: One 5870 will pretty much max everything currently out, as well.
No, adding another GPU will not void your lisence for Windows..
well thats really great to hear! I was worried about getting a OS OEM version because I have read alot of mixed reviews, some say you can upgrade parts as long as you dont do the mobo, and some say you cant add anything.
Also, what is the difference between the xfx and saphire and other manufactures version of the 5870? Do you like the xfx because of personal preference or is there some proof to back it over the others?
XFX comes with a better warranty on their stuff than the other manufacturers, all of their cards come with a double lifetime warranty as long as you register it within 30 days of purchase. They tend to be slightly more expensive but if the price is equal, as it is with the 5870s then XFX is definitely the way to go.
XFX and Saphire are pretty much the two best Manufacture of ATI cards. Why I recommend XFX is based on price and personal perference. You will be okay with either or of the two.
