Problem when i try to overclock my q8200
hey guys
i have core 2 quad q8200 2.33
and m.b Gigabyte : g31m s2c ram:800mhz
when itry to overclock i use
CPU Clock Ratio =7
CPU Host Clock Control = Enable
CPU Host Frequency = 340
Memory System Multiplier =1.6
CPU Voltage =1.28v
PCI Express Frequency =100
Performance Enhance = Standard
Advanced Bios Features
CPU EIST Function=Disabled
PC Health Status
CPU Smart Fan Control=Disabled
so when i click F10 to save the pc restart and run again
then the its freeze on this screen
or in the second screen ( so i was need to to remove motherboard battery
And installed it again to get the default bios and the pc run again )
i try this option up the vcore to 1.30-132
update the bios to the last update http://www.gigabyte.com/products/product-page.aspx?pid=2866
F6e 2009/06/01 1.Beta bios
and same problem happens when try to overclock
plz help me what to do to fix this problem to overclock my cpu
1 answer Last reply
More about problem overclock q8200
  1. drop ratio ram to 1:1
CPUs Overclocking
