I recently built my pc and didnt think I wanted to crossfire but now I want too. BUT!!! I got a psu with only 2x 6 pin connectors and 4870 take 2. So my question is can I use 1 6pin on each card and use a 6pin to 2molax connector on differnt molax lines on each card? The only issue i see is not enough amps but if that is the only issue what harm would it cause ?? (poor performance??) Thanks in advance
It should work with no problems, split the 6 pin and the 8 pin to each GPU using the 12V3 rail and a molex connector to each card off the 12V2 rail. I'd usually rather see a 750w with the 4 PCIe connectors for crossfiring 4870s, but i wouldn't replace the 650w Earthwatts in your case.
http://www.jonnyguru.com/modules.p [...] y&reid=110
