Tom's Hardware > Forum > Homebuilt Systems > New System Build > Will this build work out?
EDIT: EDIT:
Can anyone tell me if this build works out?
Casing : Lian-Li PC-7FW Black Aluminium
Cooling Fan : Cooler Master V8
Power Supply : Cooler Master UCP 900W 80+
Motherboard : Asus M4A785TD-V EVO
Processor : AMD Phenom II X4 955 BE
RAM : Kingston HX D3-1600 / Kingston HX D3-1800 / Kingston HX D3-2000 (Which one is better?)
Graphics Card : MSI HD4890 Cyclone OC / MSI HD5870-PM2D1G
Hard Drive : 320 GB SATA 3G (3.0 Gb/sec) 7200 rpm (From HP Pavillion a6098d)
Optical drive : 16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive (From HP Pavillion a6098d as well)
This is the build. So can this work out or I should change something? Please tell me.
The link to HP Pavillion a6098d product specifications : http://h10025.www1.hp.com/ewfrf/wc [...] ct=3379050
Thank you very much in advance.
Message edited by xmexhksx on 10-02-2009 at 08:33:13 AM
Sponsored Links
work yes, I'd recommend droping the cpu to 955 BE because 965 is a mildly overclocked 955 which costs 60$ more, get the 955 BE and mild overclock it if you must.
Reply to Daggs
I think you're missing the DDR3 memory in your post.
Reply to digiex
Will any DDR3 RAM work?
Reply to xmexhksx
Well. After much consideration, I decided to get a 955 BE. Anyway just to ask. Is all Phenom II X4 955 Black Edition?
Message edited by xmexhksx on 09-29-2009 at 04:14:55 PM
Reply to xmexhksx
yes, as long as the motherboard supports it.
In dual channel configuration.
Reply to digiex
What do you recommend?
Reply to xmexhksx
What about Team Xtreem D3-1600? or Team Xtreem D3-1800? or Corsair DDR3-1600 C9 or Corsair DDR3-1600 C8?
Reply to xmexhksx
PSU is TOTAL overkill. a good 600W would do you fine unless you are looking at a 2nd card in the future in which case a good 700 or 750W would be fine. The Cooler Master UCP 700 is nice.
Message quoted 1 times
Message edited by jay2tall on 09-30-2009 at 05:37:20 PM
Reply to jay2tall
jay2tall wrote :
CPU is TOTAL overkill. a good 600W would do you fine unless you are looking at a 2nd card in the future in which case a good 700 or 750W would be fine. The Cooler Master UCP 700 is nice.
What do you mean? Means Cooler Master UCP 700 is enough? Anyway what do you mean by "CPU is TOTAL overkill"?
Reply to xmexhksx
The combination of low latency and low voltage make the G. Skill RAM a good option. It's not the only option, its just my recommendation.
Reply to pepperman
That was a total misspell. I meant PSU, not CPU... I took the UCP letters and mixed them around and got CPU instead of PSU. It was AM, coffee didn't kick in yet.
Anyways, the 700W UCP powersupply is plenty for (2) 4890's it has (4) 19A rails. I'd look into the 5850 if I was you though right off the bat. It should be out in another day or so and offers almost the performance of (2) 4890's in crossfire. It hovers around the 4870x2 at times.
Reply to jay2tall
I am getting 900W cause if next time the graphics card or if i want to change my processor to a better one, i can use the 900W.
Reply to xmexhksx
^ technically that is incorrect. The newer graphics cards consume LESS power and perform better. Same with CPU's. So if lets say you got the 700W... you would need LESS on the next gen of cards and CPU's. The only time you would need like a 900W PSU would be if you are running tons or fans, HD's, and dual GPU graphics cards. But hey... it's your money dude, I'm just trying to maximize your dollar.
Reply to jay2tall
There are 606 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
