okay i just got my 790 fx gd70 that i oreder. put in my hd 5770, plug everything in correctly. then bam, turn on the motherboard all the lights and fans come on especially the gpu fan which sounds like its at 150% speed. it will not slow down at all. also i hear crackling in my speakers that are plugged into the motherboard. the power button on the motherboard will only turn the computer on not off and it will nto reset it. the hdd led stays red (idk if thats anything important). the post led does not come on. i did not have any problems with my m4a78t-e so im wondering if i made a mistake with this one. also my monitor will nto come on. i got a vga to dvi adapter plugged into the gpu since the motherboard does not have a vga connector.
***EDIT*** just took out my memory sticks. the one closest to the cpu smells burnt. im getting error code ff. gpu fan has lowered. but the monitor still will nto come on.put a stick of ram in the mobo and goes back teh way it was.
specs:
amd phenom x4 955 be
4gb ddr3 dual channel viper extreme ram
250gb hd
800w psu.
specs:
250gb hd
800w psu.
