Hello,
i dropped my hard drive recently (it's a 1tb wd in a nexstar cx case). The first time i used it after i dropped it it worked for a minute or so before the enclosure light turned off.
now when i turn it on the hd starts spinning and after a few seconds the enclosure light turns off. after about a minute the hd stops spinning and the light comes back on. my computer then detects the enclosure as an unknown drive in disk management and when i try to initialize it it gives me a CRC error.
i've tried searching for a while to find out whats wrong with it but can't find anyone in the same situation.
is it possible to get it working again/retrieve any data considering i was able to use it for a short time after the drop?
also i have a laptop and no desktop available to hook the hd into.
thanks
jack
thanks
jack
