Archived from groups: comp.sys.laptops (More info?)
Does anyone know if there is a automobile power supply (Plugs in your power
outlet) for a emachines m5312. I can't seem to find one, emachines don't
have one on their web site.
Thanks.
"Rob" <bucfan11SPAM@earthlink.net> wrote in message
news:2hq666FfbtfvU1@uni-berlin.de...
power
> Thanks.
> Rob
This goes for all laptops:
The best alternative is,
Just buy a DC to AC adapter of 75 watts o more.
you will be glad you did.
power
> Thanks.
> Rob
The DC to AC inverter usually cost less and can be used for other low power
consumption devices.
"Sava777" <sava777@comcast.net> wrote in message
news:chTtc.7899$js4.5001@attbi_s51...
> power
> > Thanks.
> > Rob
Well, you shouldn't need any special adapter for EMachine. Just get an
inverter with enough power rating. I have a 175 watt Vector that
worked just fine on a recent trip. And it was much lower cost than the
one referenced in another reply.
Regards, hawk
> Thanks.
news:2hq93nFg1l1qU1@uni-berlin.de...
> power
> > Thanks.
> > Rob
> I found one here: http://www.shoplaptop.net/emm5m5m5m5m5.html >
Interesting: the title describes the adapter as being for emachines while
the description says Compaq. Get an inverter as the others have suggested -
they're cheaper and useful for powering other electronic devices as well.
I don't know, but it's possible that some of the "universal" air/auto
power supplies support that model.
If it has a standard "coaxial" power plug, it makes things a LOT easier.
If that's the case, it's almost always possible to find a "universal"
power supply that will work. If not, you are far more limited.
> Thanks.
Actually, I don't agree that this is the best solution, but it will
usually work. However, 75 watts is really not enough. There are
laptops that use as much as 120-160 watts, and there are LOTS of laptops
that use 75 watts or more. However, that is the laptop's AC adapter
OUTPUT rating. The power adapters are only 60% to 80% efficient, so if
have a 75 watt laptop power supply (15 volts at 5 amps, my Toshiba 1415)
that is only 75% efficient, you will need a 100 watt inverter to power
it. But the Toshiba A45 has a 15 volt at 8 amp adapter (120 watts); if
it's efficiency is 75%, you would need a 150 watt inverter.
> power
>>Thanks.
>>Rob
"Barry Watzman" <WatzmanNOSPAM@neo.rr.com> wrote in message
news:40B8B3B6.7010100@neo.rr.com...
> usually work.
What are the drawbacks to an inverter that you see? You say "usually". I'd
be interested to learn of situtaions where an appropriately powerful
inverter won't work for a laptop.
I would agree with the power requirements especially since inverters are so
cheap these days. Fry's Electronics has a Coleman branded one rated at 200
watts for $20 this weekend.
IMHO, an inverter combined with an orginal equipment AC laptop adapter is
the best solution. The OP found a car adapter for his emachines laptop but
from the ad, it looks more like a universal adapter. While that's probably
OK, I'd prefer to have my original IBM adapter plugging directly into my
Thinkpad.
> > power
> >>Thanks.
> >>Rob
The drawbacks to using an inverter vs. using an air/auto adapter to run
a laptop in a vehicle are as follows:
1. It's two physical units and a lot of wiring.
2. Both the inverter and the laptop AC adapter are only 60% to 80%
efficient. The combined efficiency could be as low as 36%; thus, it
could take nearly 200 watts from the car's electrical system to run a
75-watt laptop.
3. The output of the inverter is not sine-wave. While probably more
than 85% of inverter / power supply combinations will work, there is a
chance of it not working, or of causing overheating or even damage to
the laptop AC adapter.
An actual air/auto power supply is a better solution, other things being
equal.
>>usually work.
> Thinkpad.
>>>power
>>>>Thanks.
>>>>Rob
Well, maybe. But the rated power consumption for a PC is most likely
the peak load, say during disk spin-up, etc. My Vector inverter is
rated at 175 watts continuous and 350 watts peak, so even at 75%
efficiency of the adapter, my Vector should easily handle a computer
rated at 175 watts.
Regards, hawk
