Hi all,
I have the following system and have issues running my memory at 1066MHz:
- AMD Phenom II x4 965 (3.4GHz - Not Overclocked)
- Asus M4N78 Motherboard
- 4GB (2x2GB) Kingston HyperX 1066MHz DDR2 Memory (PC2-8500)
I have tried the following settings:
Memory Clock Mode - Manual
Memclock Value - 533MHz (x2 - 1066)
DRAM Timing Mode - Both DCT0 and DCT1
CAS Latency (CL) - 5 CLK
tRCD - 5 CLK
tRP - 5 CLK
tRAS - 15 CLK
Memory OverVoltage - Auto
However, about 5 minuted into using Windows (Windows 7 64 Bit Ultimate) I am given the BSOD. Everything is fine when using the auto settings for 800MHz.
Here is a link to the motherboard manual so that you can see the available settings in the bios:
http://pserver.x10hosting.com/E4378_M4N78.pdf
Many Thanks
RHINO89
tRCD - 5 CLK
tRP - 5 CLK
tRAS - 15 CLK
Many Thanks
RHINO89
