Tom's Hardware > Forum > Homebuilt Systems > New System Build > Thermaltake IGCS 12 Fans Won't Spin off Molex in Antec 1200 Case
Forum Homebuilt Systems : New System Build - Thermaltake IGCS 12 Fans Won't Spin off Molex in Antec 1200 Case
I replaced 5 stock fans in my Antec 1200 case with Thermaltake IGCS 12 fans. The ones I hooked to my mobo work fine. The ones I hooked to the 4-pin molex lead from the PSU (Kingwin 1000W) don't spin. Other fans (the old Antec ones) spin fine off that PSU lead. Again, the Thermaltake ones that don't spin DO spin when connected to the mobo 3-pin headers--just not when connected to the 4-pin molex. And the molex lead does successfully power other fans. Any thoughts?
Sponsored Links
Check the wiring of the fan. Do the wire colors match?
Reply to evongugg
Molex pins are standardized:
http://en.wikipedia.org/wiki/Molex
2 middle pins are both ground (usually black)
+12V should be yellow in color
+5V should be red in color
You can check these with a standard volt meter.
Also, in case you missed this detail, some
"fan only" Molex connectors have only 2 wires
but they may not be labeled as such.
If a Molex connector has only 2 active wires,
it's definitely "fan only".
MRFS
Reply to MRFS
Found this:
http://www.thermaltakeusa.com/Prod [...] =1863#Tab2
See "Product Content" at the link above.
I only see 2 pins on the Molex-to-3pin adapter above.
Do you have the speed control rheostat in-line, or not?
MRFS
Reply to MRFS
here's a clue: I found this photo of the fan's power connectors
at the Thermaltake website:
http://www.supremelaw.org/systems/thermaltake/ISGC.Fan.12.connectors.JPG
Note that the white connector (on the right) has red and black wires
but red is the standard color for 5 Volts; however,
your fans require 12 Volts i.e. "operating voltage".
See "Spec" here:
http://www.thermaltakeusa.com/ISGC/index.html
MRFS
Message edited by MRFS on 09-30-2009 at 05:29:01 PM
Reply to MRFS
There are 560 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
