Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Updated i7 System Build
Forum Systems : New Build Updated i7 System Build
This is what I'm thinking about going with. Any thoughts before I press that Order button?
MB & CPU : NCIX Gaming Bundle Deal Intel Core i7 920 D0 Processor & ASUS P6T Deluxe V2 X58 SLI Motherboard $674.78
http://www.ncix.com/products/index [...] omoid=1008
CASE : Cooler Master Haf 932 Full Tower Black EATX Case 6X5.25 1X3.5 5X3.5INT No PSU USB eSATA 1394 Audio $168.92
http://www.ncix.com/products/index.php?sku=33029
GPU : 2 x XFX Radeon HD 4870 750MHZ 1GB 3.6GHZ GDDR5 PCI-E 2XDVI HDCP Video Card $320.98
http://www.ncix.com/products/index.php?sku=42237
PS : Corsair Professional HX750W 750W ATX 12V 62A 24PIN ATX Modular Power Supply Active PFC 140MM Fan $199.99
http://www.ncix.com/products/index.php?sku=38649
MONITOR : BenQ E2400HD 24IN 16:9 Widescreen Black LCD Monitor 2MS 1920X1080 10000:1 Senseye HDMI DVI VGA $229.99
RAM : Patriot Extreme Viper PVT36G1600LLK 6GB DDR3 3X2GB DDR3-1600 CL 8-8-8-24 Triple Channel Memory Kit $149.99
http://www.ncix.com/products/index.php?sku=35294
HD : Seagate Barracuda 7200.12 1TB SATA2 3.5IN 8.5MS 7200RPM 32MB Hard Drive OEM $109.25
http://www.ncix.com/products/index.php?sku=37232
OS : Microsoft Windows Vista Home Premium 64BIT OEM DVD with Windows 7 Upgrade Offer $151.39
http://www.ncix.com/products/index.php?sku=40693
HSF : Thermalright Ultra 120 Extreme 1366RT Heatpipe Cooler LGA1366 120MM Fan FDB 1600RPM 28.0DBA 63.7CFM $75.24
http://www.ncix.com/products/index.php?sku=34994
DVD : Samsung SH-S223L/BEBS 22X SATA Black DVD Writer Lightscribe OEM $34.99
http://www.ncix.com/products/index.php?sku=42349
Total Build Cost : $2,183.01
I really fought with the idea of going with the i5 750 but with the amount of CS4 work that I do I figure that the 8 threads would come in handy. Anyone want to sway me towards going that way anyway?
Would be interested in your thoughts on this! Thanks!
Reply to mmccarthy
I would switch your GPU to XFX 5850 for pretty much the same performance in one GPU. Plus, you save $50 on your PSU with the combo.
In a few months, add a second 5850 for even better performance.
Edit: I would go with this Patriot RAM do to lower timings... http://www.ncix.com/products/index [...] re=Patriot
Message edited by tecmo34 on 09-30-2009 at 01:08:00 AM
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Thanks for the reply. I would go for that but they currently are not available. I think I'm going to order this tomorrow if no one can come up with something wrong or something to add to this build. Does the lower timings improve performance or is it another reason?
Reply to mmccarthy
Lower timings provide better performance in the RAM. Your RAM running at a CAS7 1333 MHz will perform better than a CAS8 1600 MHz.
I think it is worth waiting for the ATI 5850 but if you want to buy tomorrow, the 4870's in Crossfire will perform nicely.
Reply to tecmo34
There are 1726 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1400-1800 range, first build, need feedback
By Hopz, 4 hours ago:
I would keep the 750W for future upgrades and possible SLI in the future. Will save you...
Best offers
Top experts
