AD replication over VPN problem
Hello there,
I'm attempting to replicate my local AD over VPN to a remote machine as an RODC
My local AD is on a windows server 2008 R1 sp2
Remote machine is a windows server 2008 R2 sp1 and has a public IP
I'm using a windows PPTP vpn connection.
The two machines seem to be communicating well, I start the dcpromo and fill every bit of information, replication starts, and always fails at the same step "The Operation failed because : While promoting Read-Only Domain Controller, failed to replicate the secrets from the helper AD DC. The RPC server is unavailable".
I used to have the rpc error thing from the very start because i did not tell the remote machine to use the local AD as prefered DNS.
I have tested the replication with a local machine and everything went ok,
edit : at first this looks very much like a dns error, but, then i edited the hosts file on remote and local machines and added the vpn addresses (10.0.0.0) so that there would be no mistakes, and i still get that error at the same step.
Thanks for your help.
3 answers Last reply
More about replication problem
  1. Your better off replicating on a local network and then change the ip and routing etc for vpn rodc.
  2. Remote machine can only be contacted through internet
  3. Used OpenVPN and it's all working great :)
Management Windows Server 2008 vpn Business Computing
