Yes No
Ads
Tom's Hardware > Forum > Overclocking > Graphics Cards > GTX 470 Overclocked and Now Problems
Forum Overclocking : Graphics Cards GTX 470 Overclocked and Now Problems
Hey all,
So I am a video editor and realized I could get some extra oomph out of my GTX 470 if I overclocked a bit to help out with the mercury playback engine. So using EVGA's precision tool I did just that. I wasn't sure what I was doing so I did some research and ended up using some settings found on the review of the card on Amazon of someone saying they were able to run at those settings on air cooling no problem.
So I did it and things were running fine, and I decided to do a restart. That's when the trouble started. I began to get a black screen where I could use the mouse to move around and that was it. The only thing I remember doing before this happened was clicking the "apply to startup" button in Precision. So I then wanted to undo this in safe mode but the program would not run.
After a few attempts at just restarting and getting nowhere I ended up on uninstalling Precision and the videocard drivers, which got me back to desktop. Windows 7 installed its own drivers, and I reinstalled precision.
I then uninstalled drivers, attempted to install the latest ones I downloaded, but for some reason it could not install and so I rebooted only to be met with a black screen again. Hit the reset button and met it again but decided to leave it for a while and hit ctrl alt del.
After a while, the prompt for task manager showed up and everything loaded. I installed the new driver and attempted to get back to editing but a box popped up saying it could not do Mercury Playback anymore, and when I tried to re-enable it, it was greyed out. I restarted the PC, and was met with a slower loading machine.
TL;DR - Overclocked GPU a bit, got black screen, uninstalled precision and drivers, set it back to default but still getting a period of black with a movable cursor before the desktop shows, and it takes a while for the PC to be fully responsive even though I put settings back to where it should be. I also ran CCleaner to clear out registry and restart.
As it is startup is noticably longer with the black screen before desktop loads. WHAT DO?
Reply to evan_s
I need to know what clocks and fan settings you left the card at when you decided to shut down? Do you have a second comp to test the card? Being an honest person I will say that you should have gotten a second card just for mercury playback engine if you had a second slot and the psu was able to handle the load. Beyond that I think the problem is software to blame for your troubles right now.
Reply to nforce4max
Sadly, I do not have another video card to test with. Since this is my work (and play) machine I am thinking I should probably not bother with the overclocking thing at all not having any backup machine (or card) to fall back on and work to get done.
The only reason I would need a second video card is if I want to get a third monitor, which I do, in fact want to do since apparently the 470, among other cards, can only handle 2 displays at a time even though they have more than 3 outputs.
I was and currently am using the latest NVidia drivers.
Stock settings on the card are 1215 Processor Clock and 1674 Memory clock, where they are back at now.
I had them at 1435 processor and 1800 memory. Temperature was about 67, whereas right now back at stock I am at 65.
http://i.imgur.com/UY9Po.png
http://i.imgur.com/UJVyO.png
Reply to evan_s
Oh and I agree, it's software for sure. If I could get a little extra out of my card that would be great since I think I got a noticeable difference when I overclocked. The problem came when I hit the "apply at startup" button and restarted.
I am wondering if I could just adjust the settings manually when the computer is already started, edit with those settings, then go back to default when I am done?
Reply to evan_s
47C for CPU and 65C for GPU Idle?
Have you got any fans in that case? those temps are scary download coretemp and GPUZ and check the temps on those.
------------------------------ Core i5 2500k @ 5.02ghz 1.51v 8 Hours Prime95 Stable (@ 4.6Ghz 24/7) w/ Phanteks PH-TC14PE, ASUS P8Z68-V-PRO , 8GB Corsair Vengance White, Sapphire R7870 2GB @ 1250/1450, WD Caviar Black 640GB
Reply to deadjon
It's a HAF 932 case and yes there are a few fans in there, and the CPU cooler is a coolermaster, not stock.
It may not be a proper "idle" since I would have had premiere running but not doing any encoding or anything, therefore nothing intensive happening and CPU would be running at nothing more or less. I now just have chrome open with some tabs.
Here's where I'm at
http://i.imgur.com/jLetd.png
http://gpuz.techpowerup.com/12/01/03/e24.png
The default for the fan in Precision is at 40 set on Auto - maybe I should make it manual and bump that up?
Message edited by evan_s on 01-03-2012 at 04:31:48 PM
Reply to evan_s
I prefer manual to be honest. My habit is that I go for 80% when windows has just booted up and leave it there till I shut down. Keeps temps low though out the entire day.
Reply to nforce4max
one thing that can really help you out is re-installation of windows
------------------------------ khuda ko dikh raha hoga,
na dil tujhse judaa hoga
teri taqdir mein mujhko,
woh ab to likh raha hoga
Reply to truegenius
Well I just threw the fan up to 80 and boy is that loud compared to hearing nothing. Is that even safe? On the plus side I went from 65 to 50C
Reinstalling windows is not something I can afford to do right now. Too much to get done. But really, the card comes with an overclocking program, shouldn't I be able to up the settings a bit on air cooling no problem?
Could it possibly have been voltage needed to be increased as well?
Reply to evan_s
80% fan is safe even 100% is also safe, but are loud
i use my fan at 100% when gaming (too noisy) and thats why i use head phones during gaming
have you tried system restore
Reply to truegenius
No I haven't, I don't think that is the issue. What I did find on the EVGA forums was a post detailing how to properly install drivers, and apparently NVIDIA HD AUDIO can cause the same period of black before desktop loads that I mentioned, so I had to clean out my drivers, install how they recommend and that seems to have fixed everything. I hope.
Reply to evan_s
I have feeling your card overheated. DId you test for stability when you OC'ed?
Reply to shoot you
There are 1679 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Does a computer NEED ram?
By Motopsychojdn, 1 hour ago:
A Pc will not function without ram, simple as, can you post the model/make of your Pc and...
Best offers
Top experts
