Hi all,
I'm building a system with the GA-X58A-UD3R and it has both ATX and ATX_12V_2X power connectors. The manual is a little vague making it sound like I might need to use both, but then again, maybe only if I'm using an extreme edition CPU (which I'm not). I'm using a core i7-930 cpu and Corsair HX750 PSU.
My question is do I need to use both connectors or not? This is my first build if you can't tell .
Thanks!
Thanks!
