Solved
Can I power up a PSU without hooking up a MB?
  • Power Supplies
  • Power Up
  • Motherboards
  • Components
Last response: in Components
December 18, 2009 12:13:03 AM
I am waiting for a motherboard to show up. But I want to test my fans. I would like to use my currently idle 750W PSU as a source of 12V to test various fans.
Is there a way to "turn on" a PSU without hooking it up to a MB?
More about : power psu hooking
Best solution
a c 243 ) Power supply
a b V Motherboard
December 18, 2009 12:16:10 AM
Yes, jump the green ( Power_On ) pin with any ground pin on the main connector
December 18, 2009 12:21:35 AM
Thanks. I'll go check it out.
m
l
a b V Motherboard
December 18, 2009 12:23:41 AM
Make sure the switch is off before you jump the pins :o
m
l
December 18, 2009 1:11:20 AM
Thank you. It's always good to have someone remind you of things like that.
Any notion of what color wire the ground should be?
m
l
a b V Motherboard
December 18, 2009 1:20:48 AM
Black
m
l
December 18, 2009 1:57:57 AM
Thanks!
m
l
December 18, 2009 3:29:09 AM
Just ran a bunch of fans. Now that they're at 12V instead of 17+V, they are much quieter.
m
l
