Tom's Hardware > Forum > Graphic & Displays > ATI > Sapphire HD4870 not sending signal to monitor
Forum Graphic & Displays : ATI - Sapphire HD4870 not sending signal to monitor
Hello. I bought a new CPU E7500 for my home PC and I'm having a problem that won't let me sleep. After installing the new CPU my Sapphire HD4870 won't send any signal to my monitor, unless, ATTENTION PLZ, I unplug the PC and plug it again or I manually shut it down pressing the power off button for a few seconds. So after any restart or shutdown from software, won't work. I'm only guessing that its my videocard btw, but it's still wierd tho, as I used the HD4870 with my old CPU E4500 and there was no problem.
Sorry for the horrible english and thanks in advance.
Btw this is the configuration I'm using:
CPU: Intel Core 2 Duo E7500
Mobo: Intel DP35DP
Video: Sapphire HD4870 1gb (standard one)
PSU: Gembird 650W
Memory: 4Gb (4x1Gb) DDR2 Pc2-6400 (400MHz) Kingmax
Monitor: BenQ 2420HD
Sponsored Links
Ok, a small correction. Unplugging the PC wont solve the problem, i guess i read too many forums trying to solve the problem and got influenced.
Shall I install my old videocard Leadtek WinFast 8600 GTS to see if the problem still persists, so we know if it's the CPU or GPU?
Reply to nerevah
There are 1140 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
