Help choosing new motherboard
Well basically Im not sure what to choose from here. I am looking to get a new motherboard.
I have a dual core extreme QX6800 atm. I have the p5n32se deluxe asus board atm but only 2 slots work on the memory...
I want an upgrade on the MB as I am getting windows 7, any suggestions would be helpful thanks.
3 answers Last reply
More about help choosing motherboard
  1. Why a new motherboard when you can get a 2x2GB RAM kit?
    If you are upgrading the motherboard you probably should go with a new CPU and DDR3 RAM also.
    ...cause I would like a new mb. As well my current bios will not recognize 4g, the bios update does not work on this mb - via complemants of asus. But yeah for a veteran, you didnt answer my question. As far as a new processor....why, even the new i7 extreme isnt godly compared to the current one i have :/
  3. Its hard to make a good recommendation with no info. If you just wanted 4GB RAM for Win 7 then a 2x2 RAM kit would have given you what you needed far easier. You current motherboard not handling two 2GB sticks was kind of important to understanding why you want a new motherboard.
    There are still tons of socket 775 motherboards that will handle 4+GB RAM. May not be the case in a year so dont wait too long.
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010200280%201070509908%201388027176&bop=And&ShowDeactivatedMark=False&ActiveSearchResult=True&Order=PRICE
    In this list I would stick with ASUS, DFI, MSI, Gigabyte or EVGA. Since I have no idea what your other system requirements are I cant help you narrow it down any more.
Motherboards Dual Core
