Possible short problem - plz advice
  • Motherboards
  • Biostar
March 20, 2010 10:13:03 AM
Hello,
I just bought my biostar I55 motherboard and lately my PC did not open , after I uninstall and install some of the components again my PC return to work !
I experienced the same problem in my previous gigabyte motherboard , and when I touch screw electricity tester to any part of my inside case the tester led goes on, is that normal ?
I was also thinking of placing the antistatic plastic bag of motherboard under it so it help for more protection but I am worried about the over heat that may cause ! please advice
thanks
More about : short problem plz advice
a c 156 V Motherboard
March 20, 2010 12:08:37 PM
It sounds like you have a grounding problem the the wall AC socket. Two computers had the same problem.
Do you have the same problem if you move the computer to another room (different electrical circuit)?
If you reused the power supply from the earlier computer, that or the power cord could be the problem also.
m
l
March 20, 2010 12:23:31 PM
I cant move the PC but I was in different room before and the same problem happen, and I use the same cord but I use APC UPS , is this should protect me or is it the problem ?
do think if I placed the antistatic bag under the board will help ?
thanks
m
l
