Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Hmm still having problems
Forum Homebuilt Systems : General Homebuilt - Hmm still having problems
Ok i dont know how many of you guys know but about a month ago my mobo decided to crap itself! I was running...
XFX 8300 mobo
AMD Phenom II 940BE
4gb corsair dominator ram
HIS 4890 turbo edition 1gb
corsair TX650W PSU
ok so the mobo blew and now i have purchased a
DFI Lanparty DK 790FXB M2RSH
everything else in my PC is what is was before and it runs great... most ot the time. Ok so the issues r as follows
GRID runs fine on max graphics BUT when i try to change the graphics i get a black screen with light grey lines down it and have to do a restart?
CRYSIS also runs max at about 30fps but sometimes it will crash after 10 mins and the pc will restart other times i can play it for 10 hours at a time with no probs
GTA4 does the same as crysis
Other notes..
I am running vista fully updated
i have the latest drivers for all my hardware
nothing overheats and as my graph card is a turbo edition its runs OC'ed at about 70 deg
does ne1 know my prob i think personally its a compatibility issue with Radeon and the games i am playing
as i had no probs with my old 8600GT OC but if ne1 has ne idears it would be verry helpful thnx
------------------------------ XFX 8300 MoBo
HIS HD4890 Turbo
4gb Corsair Dominator Ram
1TB HDD
Sponsored Links
Your crashes in Crysis/GTA4 are probably something else, as those should run fine. These are full system crashes and automatic restarts? That seems like a hardware issue. Have you run memtest from a boot disk?
http://www.memtest.org/
Is your RAM running at the correct voltage and timings?
Check all your temps, not just GPU:
http://www.cpuid.com/hwmonitor.php
I would expect GRID to run well also, but perhaps it's a driver issue or such.
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
I know that Corsairs are good PSU's (I have a TX750), but could you be having some kind of power problem?
Reply to jsc
Did you reinstall your os after you changed mobos?
Reply to pepperman
Did you do stability testing after OCing the GPU? I had similar erratic graphics lockups/dropping out of game. I backed the GPU OC off a bit and havent had any more troubles.
Reply to dndhatcher
Ill check my ram this whole mobo seems to have thrown out my settings could this be the problem? for eg. my processor is fine but as you said my ram is running at 800mhz and its corsair dominator 1066mhz
These are the power requirements so i may have a probem here as the requirements added together = over 900w
DFI Lanparty DK 790FXB M2RSH - 300w
AMD Phenom II 940BE -125w
4gb corsair dominator ram - not much
HIS 4890 turbo edition 1gb - 550w
corsair TX650W PSU
i will also try down clocking my GPU at the moment it runs at 900mhz but factory spec 4890's run at 800-850 i didnt do stability testing as the card is a turbo edition it is factory OC i dont tamp with it :p
yes i installed a new OS after i got the new mobo
Message edited by Killer_au on 10-02-2009 at 04:06:45 AM
HIS HD4890 Turbo
1TB HDD
Reply to Killer_au
DNDHATCHER your idea seemed to have worked but it has to be power as the 4890 run fine OC'ed with my old mobo, it used a lot less power. but yeah im now running my 4890 @ 825mhz. 1 more question take a look at the image below this is after running GRID on Ultra @ 1680 x 1050 for about 10 mins should my processor have got to 60deg?
[IMG=http://img19.imageshack.us/img19/2343/runninggrid.jpg][/IMG]
HIS HD4890 Turbo
1TB HDD
Reply to Killer_au
Those power requirements aren't meant to be added, they're meant for the highest one to be taken and used to determine a suitable PSU. In this case, the 4890 at 550 W. This means that you need a PSU of at least 550 W (I won't go into detail about rails, as that's a little complicated).
This is a nice program to get a loose idea about your computer's power requirements;
http://extreme.outervision.com/psucalculatorlite.jsp
As for your temp, the 940 should stay below 62 C. Knowing this, yes, your cpu appears to be running hot. Is your CPU fan stock or aftermarket?
Reply to pepperman
Not that you should'nt consider a problem with the PSU but figures are off/
DFI motherboard about 15w
Amd 940BE 125w all out 200w
4 gb ram about 12w
His 4890 1 gig 90 idle about 210w all out
Hard drive's others about 30w
Not acurate by any means but about 470w total under normal load
Set bios for ram to EPP clock and EPP voltage if present. Otherwise manually set to 533x2 and 2.1volts.
If anything else was damaged when old board went you'll find out. Sounds like corruption of some video files which can happen but after setting ram correctly, removing over clocks which arent factory set, removing and reinstalling drivers you'll have a better idea. You can overclock after fixing everthing and getting stable. Sometimes I forget to get the updates for some of my programs after reinstalling from scratch.
Reply to roonj
The rest of your info is correct, but the tdp of a cpu (125 W in this case) is the total displacement power, meaning that that is the max power the cpu will ever use at stock volt and clock. If a tested cpu can't operate under those power constraints, they are either shipped a lower clock or recycled.
Reply to pepperman
hey guys thanx for the help i will try to set my ram correctly. its the stock phenom cooler but ppl have the stock cooler witch has copper pipping set @ 4.2 ghz stable
its Black edition so its built for it. neways my whole system runs at stock clocks everything is at factory settings
this is another print screen after running grid for about 1hour 70deg??
[IMG=http://img14.imageshack.us/img14/7271/runninggrid2.jpg][/IMG]
also in my user manual for my mobo it says you must have a minimum 300W PSU??
and the graph card is a HIS turbo edition and in that user guide it says minimum 550W PSU??
HIS HD4890 Turbo
1TB HDD
Reply to Killer_au
Your cpu is running too hot, then. You can try to reseat the heatsink, but you may want to buy an aftermarket cooler. The reason some can get the cpu up to 4.2 GHz stable on the stock heatsink is because not every chip is the same. If you have a cpu that requires less power to achieve the same clock, you can get impressive OC's on stock heatsink. Your cpu, however seems to require a little more power.
The PSU that's listed in your info (the 650 W) is plenty. You won't need more unless you want to CF, and even then, you might be fine.
Reply to pepperman
Cool thanx for the help again i have my ram running @ 1066mhz now so thats help but the cpu is still getting hot. where can i get an aftermarket cooler and whats the best thing for phenomII i have never looked into this side of things so i dont know what to look 4.
HIS HD4890 Turbo
1TB HDD
Reply to Killer_au
What case are you using and how many fans does it have? It could also be an airflow problem.
www.frostytech.com is one of the premier CPU cooler review sites.
Something like this Coolermaster Hyper 212 plus ($30)
http://www.newegg.com/Product/Prod [...] 6835103065
But even that wont help much if your case isnt venting the hot air out.
Reply to dndhatcher
Kewl ill check them out, i have a Thermaltake M9 with 4 140mm fans, 1 sux in the front, 1 sux out the back, and the other 2 suck in the side
HIS HD4890 Turbo
1TB HDD
Reply to Killer_au
I am in the US so I price in US dollars.
Try finding one with a good review at www.frostytech.com .
Here is the Hyper 212
http://www.techbuy.com.au/p/78580/ [...] H-LB12.asp
Scythe Mugen 2
http://www.techbuy.com.au/p/100618 [...] G-2000.asp
This xigmatech balder appears to be a nickel colored version of the dark knight.
http://www.techbuy.com.au/p/126240 [...] H3-U06.asp
Message edited by dndhatcher on 10-02-2009 at 07:37:22 PM
Reply to dndhatcher
Thanx heaps i think ill go with the Scythe Mugen 2 i stumbled on it the other day aswell and every1 seemed to think it was pretty leet.
HIS HD4890 Turbo
1TB HDD
Reply to Killer_au
There are 1198 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
